Grand Motors banner Euro Auto banner Auto otpad Sole banner Led Shop banner Knežević Enterijer banner Faber auto delovi banner
Ford Fiesta 1.4 b (2008)
Porukaod Goxy81 » utorak, 10. jan. 2017. u 00:28h
U januaru prosle godine mi se prvi put upalila zuta lampica sa znakom uzvika u toku voznje...ugasio sam auto i upalio,
Posle se vise nije palila, negde u maju 2016 kad sam bio na servisu pitao sam majstora cisto informativno sta bi moglo da bude....
on mi je tada rekao da je verovatno neki senzor u pitanju i da ne brinem.
Krajem godine sa pocetkom niskih temperatura, poceli su problemi sa tom istom lampicom, u toku voznje se upali ta lampica, motor i dalje radi, jedino papucica gasa ne reaguje....desava se bar 2 puta u toku voznje na nekih 15 km i to vec pocinje strasno da iritira.
U uputstvu sam gledao sta znaci ta oznaka, pise....problem sa automatskim menjacem...koji ja nemam :( :wtf:
Hvala unapred na odgovorima :ford:
Goxy81
Poruka: 3
Član foruma od:
ponedeljak, 9. jan. 2017. u 23:40h
Re: Ford Fiesta 1.4 b (2008)
Porukaod mbole » utorak, 10. jan. 2017. u 01:27h
BIce da nisi procito do kraja, ili je neko prevodio "nako"
Powertrain warning lamp
Vehicles with an automatic transmission
If the powertrain warning lamp comes on when the engine is running, this indicates either a malfunction or a high transmission temperature. Stop your vehicle as soon as it is safe to do so and carry out the following:
Select P or N and allow the engine to idle for 10 minutes.
Switch the ignition off and restart the engine.
If the powertrain warning lamp comes on, switch the ignition off and have the transmission checked before continuing your journey.
If the powertrain warning lamp does not come on, continue your journey and have the transmission checked as soon as possible.
Vehicles with a 5-speed manual transmission or Durashift EST
If the powertrain warning lamp comes on when the engine is running, this indicates a malfunction. The engine will continue to run but it will have limited power. Have this checked as soon as possible.
If the powertrain warning lamp flashes when the engine is running, this indicates a malfunction. Stop your vehicle as soon as it is safe to do so. Have this checked before continuing your journey.
Sve u svemu, cuvena check engine lampica.
Sto kaze milan-gt: ne sekiraj se, naje*o si :)
Vreme je za posetu majstoru.
Mondeo, Mk2, 1998, 1.8TD, Ghia, naftarica je naravno karavan
Poruka: 6680
Član foruma od:
ponedeljak, 6. jun 2011. u 22:09h
Porukaod SCORPIO123 » utorak, 10. jan. 2017. u 11:26h
bice da je klapna gasa pocela da otkazuje
SCORPIO123
Poruka: 452
Član foruma od:
sreda, 11. nov. 2015. u 20:43h
Porukaod DULEmajstor » utorak, 10. jan. 2017. u 17:15h
Imao sam identični problem na istom motoru.
Zamenio sam kompletan leptir gasa i resio problem.
Nov deo je koštao 480e, falš je bio 450e, a ja sam kupio polovan na otpadu Simo&Gile za 50e i radi već godinu ipo bez problema...
DULEmajstor
Poruka: 202
Član foruma od:
ponedeljak, 21. nov. 2011. u 08:37h
Lokacija: Josanicka Banja
Porukaod SCORPIO123 » utorak, 10. jan. 2017. u 20:48h
nema tu falsa bosch 250eur
SCORPIO123
Poruka: 452
Član foruma od:
Porukaod van » utorak, 10. jan. 2017. u 23:24h
Јел има та клапна неки степ мотор или је само тпс сензор на њој ?
Poruka: 5949
Član foruma od:
petak, 10. okt. 2008. u 08:33h
Porukaod SCORPIO123 » sreda, 11. jan. 2017. u 09:11h
step motor nema, ima servo motor koji upravlja klapnom i tps. menja se kompletna nema tu pomoci.
SCORPIO123
Poruka: 452
Član foruma od:
Porukaod Goxy81 » četvrtak, 12. jan. 2017. u 08:17h
Bio sam juce na dijagnostici, prijavljuje gresku UO122. Majstor je spomenuo klapnu gasa, ali drugacija je oznaka greske i ubedjen je da nije to...Kaze ili je greska u kompu ili je snop na konzoli (to i pise pored greske).
Goxy81
Poruka: 3
Član foruma od:
Porukaod SCORPIO123 » četvrtak, 12. jan. 2017. u 08:44h
u0122 greska vezana za abs. moze i ovo da ima veze sa kvarom zavisi sta imas od opreme na vozilu.
SCORPIO123
Poruka: 452
Član foruma od:
Porukaod mbole » četvrtak, 12. jan. 2017. u 08:52h
Typically the causes for this code to set are:
Open power or ground to engine/powertrain control module ECM/PCM – most common
Open in the CAN bus + circuit
Open in the CAN bus - circuit
Short to power in either CAN bus circuit
Short to ground in either CAN bus circuit
Rarely - faulty control module
Read more at: https://www.obd-codes.com/u0122
Poruka: 6680
Član foruma od:
Porukaod SCORPIO123 » četvrtak, 12. jan. 2017. u 09:48h
Vehicle Dynamics Control (VDC) ili po starom nazivu abs
SCORPIO123
Poruka: 452
Član foruma od:
Porukaod mbole » četvrtak, 12. jan. 2017. u 10:28h
Jeste, samo generalno se on prvi javi, a problem je ustvari komunikacija na can bus-u
Poruka: 6680
Član foruma od:
Porukaod SCORPIO123 » četvrtak, 12. jan. 2017. u 10:43h
mbole prevedi ti to meni na srpski.po tvom misljenu u cemu je ovde problem
SCORPIO123
Poruka: 452
Član foruma od:
Porukaod DULEmajstor » četvrtak, 12. jan. 2017. u 11:00h
Ja sam imao istu tu gresku, i promenio sam zadnji senzor ABS-a ...
Ali ubrzo potom je izbacio još neke greske i onda sam zamenio i klapnu gasa, i od tad auto radi normalno vec godinu i po, sto se toga tiče...
DULEmajstor
Poruka: 202
Član foruma od:
Porukaod mbole » četvrtak, 12. jan. 2017. u 11:55h
Sama greska govori da nema komunikacije sa VDC (tj abs/asr...) modulom.
Ta komunikacija ide preko CAN bus-a.
Razloga za gubitak komunikacije moze da bude vise, a najcesci su problem sa zicama/kontaktima.
Najcesci je gubitak mase ili napajanja na PCM-u, neki prekid u zicama CAN bus-a, ili kratak spoj izmedju CAN bus-a i mase/napajanja, a najredji je da je vrisnuo sam modul abs-a.
Naravno, napamet niko ne moze da zna sta je od toga.
Poruka: 6680
Član foruma od:
Povratak u Kvarovi i popravke
Ko je prisutan
Korisnici koji trenutno razgledaju ovu kategoriju: nikola, Yahoo [Bot] i 9 gostiju
