Ciscenje/zamena uljne pumpe na RS2000
Nije mesto za kvarove.
Poruka: 5701
Poruka od popovicvl » petak, 14. sep. 2012. u 08:23h
Ovih dana ceprkam oko auta i hocu da resim jedan problem koji me prati neko vreme i sad mi postaje iritantan. Kad auto odstoji, pri paljenju pocnu da zveckaju hidraulucni podizaci. Kad ce malo zavrti motor prestanu da zveckaju, ili kad se motor zagreje. Nakon toga sve je glatko do sledeceg duzeg/nocnog stajanja.
Stvar se cini mi se malo skomplikovala nakon zamene ulja koje je sad 10-40 (5-30 nisam nasao u NS da kupim :wtf: , nema?), malo duze mu treba da nalije podizace, valjda gusce ulje, sporije tece. Nakon toga sam dosao do ovog vrlo interesantnog teksta u kom sve lepo pise jer sam poceo da sumljam da je problem u donjem delu motora (uljna pumpa), ne u gornjem (podizaci)
http://www.rs2000-16v.co.uk/newsitefiles/buyers.htm
Noisy tappets, the injectors make this a tricky test as they are also noisy but if the tappets are noisy or become noisy when the oil is hot then this could point to a oil pump problem, it's been noted a few times that the oil pressure regulator that's fitted to the oil pump becomes lose and reduces the oil pressure to the engine, the oil pressure warning light is set to 10psi so will not tell you if you have this problem. If the car your looking at has had an after market oil pressure gauge fitted then the oil pressure at cold start should be about 60psi falling to between 30-40 psi when hot. Pressure should not drop to below 25psi when idling. The pump is a fairly easy fix but requires the engine lowering to enable access. If you have a noisy tappet then its an expensive fix as the original design has been replaced so you would have to replace the full set of 16 tappets and springs, This is a head off job so becomes quite expensive.
Moze li neko objasnjenje i koliko bi me kostalo para/zivaca da zavrsim ovo.
Poruka: 5701
Re: Ciscenje/zamena uljne pumpe na RS2000
Poruka od popovicvl » petak, 14. sep. 2012. u 08:45h
Na sta se tacno odnosi oil pressure relief valve.
Definitivno je problem u njemu, hteo bih to da resim pre nego se sjebe nesto.
BokiRS
Neizleciv
Neizleciv
Poruka: 4459
Poruka od BokiRS » petak, 14. sep. 2012. u 09:22h
kada skines uljnu pumpu videces sraf na njoj, to ti je taj ventil. on zna da se popusti pa moze da pravi problem.
Chip tuning za Ford-ove
viewtopic.php?f=94&t=19067
Poruka: 5701
Poruka od popovicvl » petak, 14. sep. 2012. u 11:02h
To je ovo?
Vidim da na forumu RS2000-16V dosta pricaju o ovom problemu. Moram to videti sto pre.
Dragomir
Oficijalni serviser
Oficijalni serviser
Poruka: 5507
Lokacija: Avala-BG
Poruka od Dragomir » petak, 14. sep. 2012. u 11:04h
Da to je taj sraf.Izvadus pumpu napolje i podmazes sraf i stegnes dobro
Poruka: 5701
Poruka od popovicvl » petak, 14. sep. 2012. u 11:09h
Hvala Dragomire na pojasnjenju. Prepusticu majstoru da to sredi.
Poruka: 15311
Poruka od mbole » subota, 15. sep. 2012. u 10:14h
Jedino sto se ovaj engleski post ne odnosi na tvoj problem, i cisto sumnjam da je to u pitanju.
Obrati paznju na:
popovicvl piše:if the tappets are noisy or become noisy when the oil is hot then this could point to a oil pump problem
A tebi se desava upravo obrnuto.
Poruka: 5701
Poruka od popovicvl » subota, 15. sep. 2012. u 10:42h
Znam, tacno, kontam da je to pocetak problema. Ako nastave da stekcu i dok je motor zagrejan, onda zasigurno imam problema i sa hidraulicnim podizacima i pritiskom ulja.
Posmatram ceo problem i logicki, kad upalim auto pocnu da stekcu podizaci, zavrtim motor na 3000-4000 sekundu/dve i oni zavrse steckanje. Ako ne podignem obrtaje stekace dok se ne zagreje auto, tj. ventili. Ovo meni ukazuje na problem pritiska ulja. Problem je bio manje izrazen sa 5/30 uljem, nego sad sa 10/40. U ponedeljak cu da ga odvezem da se skine uljna pumpa, ocisti, pritegne pa cemo da vidimo dalje ako bude problema.
Poruka: 10019
Poruka od macaneli » subota, 15. sep. 2012. u 11:13h
a da se vratis na 5w-30?
Poruka: 15311
Poruka od mbole » subota, 15. sep. 2012. u 11:24h
Pritisak ulja je veci dok je ulje hladno nego kad se zagreje (pogledaj ponovo engleski post, na hladnom je pritisak 60psi, a kad se zagreje 30-40psi).
To ce reci, problem bi trebalo da se manifestuje obrnuto, odnosno da krene da se prvo pojavljuje na vrucem motoru, a ne na hladnom.
Dusan64
Poruka: 5280
Poruka od Dusan64 » subota, 15. sep. 2012. u 11:29h
Jel filter ulja ima onaj ventil koji ne dozvoljava vracanje ulja u karter?
Poruka: 5701
Poruka od popovicvl » subota, 15. sep. 2012. u 13:19h
Stavljen je ovaj filter po katalogu FILTRONA.
http://www.filtron.pl/en/index.php?idp= ... 0#idn12892
Pise da ima, mada sta god da pise pitanje je da li stvarno ima "Anti-Drain Valve". Pre dve godine su mi majstori ugradili filter sa "4 rupice", lupao je cudo bozje po 10 min. Odmah sam posumljao na neadekvatan filter, zamenio sa filterom od sierre 2.0 (kratak i debeo :P ) isti dan, prestalo je da lupa. Ovog puta sam stavio ovaj po katalogu u radnji. Ne bi bilo lose da nadjem original filter?
macaneli piše:a da se vratis na 5w-30?
Nema u kantama od 5l vec neko vreme? Samo po litar. Uzeo sam ovu kantu 10-40, nece mu nista biti, i onako cu preci 5 000 do sledece godine pa cu zameniti.
Poruka: 5701
Poruka od popovicvl » subota, 15. sep. 2012. u 13:50h
Hmm, ovo je original motorcraft Filter za RS2000
Na njemu se vidi da ima 8 rupa, kratak model. Poprilicno se razlikuje od Filtronovog iz kataloga. Toliko o Filtronu.
Gde mogu naci Motorcraft EFL90 filter?
Poruka od totti » subota, 15. sep. 2012. u 13:55h
Motorcraft filtera ima kod Tanasica, danas sam video. I ja sam na 1.6 Focusu nekad imao krace, nekad duze filtere, nije mi pravilo problem.
popovicvl piše:Nema u kantama od 5l vec neko vreme? Samo po litar.
Popovicu, nije valjda ovo razlog? :wtf:
Poruka: 5701
Poruka od popovicvl » subota, 15. sep. 2012. u 14:02h
Jeste. Mada nece mu nista biti sa ovim uljem, nece okrenuti ni 5000 i menjace se. Sa proslim 5/30 sam docekao 9000, preterao sam.
BokiRS
Neizleciv
Neizleciv
Poruka: 4459
Poruka od BokiRS » subota, 15. sep. 2012. u 14:10h
vrati se na 5w30 i stavi original filter
Dragomir
Oficijalni serviser
Oficijalni serviser
Poruka: 5507
Lokacija: Avala-BG
Poruka od Dragomir » subota, 15. sep. 2012. u 14:27h
Ima kod mene filter orginal(moram imati na stanju zbog Markedjanija)
Poruka: 5701
Poruka od popovicvl » subota, 15. sep. 2012. u 19:03h
Promenio sam filter. Muller, iz kataloga potpuno drugaciji od Filtron iz kataloga. Kratak, zdepast, sa 8 otvora na dnu. Stekanje je jedna ruzna proslost za RSa. Jebes Filtron i njihovo poznavanje problematike.
Nece mu nista biti sa 10/40, nije to 1.6 Zetec da se rasatavi na sastavne delove kad se sipa pogresno ulje.
Poruka: 21946
Poruka od Markedjani » subota, 15. sep. 2012. u 19:15h
Samo ti njemu sipaj 5w30 u kombinaciji sa original filterom za ulje i nećeš razmišljati o lošem podmazivanju.
A i 5w30 je idealna priča za ovo nadolazeće hladnije vreme.
Poruka od totti » subota, 15. sep. 2012. u 19:18h
popovicvl piše: nije to 1.6 Zetec
Ne znam šta da ti kažem, 1.6 ne drlja ni sa dugačkim filterom :D
Poruka: 10019
Poruka od macaneli » subota, 15. sep. 2012. u 21:43h
kakve veze ima dal ima kantica od 5l ili su 5 pakovanja od 1l?Jel ima neka razlika u kvalitetu?
Poruka: 15311
Poruka od mbole » subota, 15. sep. 2012. u 23:01h
5X1 je skuplje oko 2 evra od 1X5 :)
Poruka: 10019
Poruka od macaneli » subota, 15. sep. 2012. u 23:01h
Poruka od van » nedelja, 16. sep. 2012. u 00:48h
Zetec су квалитетни мотори ,можада су и бољи од N7A, a ти мислиш на zetec SE
Poruka: 5701
Poruka od popovicvl » nedelja, 16. sep. 2012. u 01:39h
Ma kakve veze ima da li se vozi na 5W30 ili 10W40. Zimi auto spava u garazi, nece mu biti nista. Na autu menjam ulje na 5-6000 u proseku, sad sam dogurao do urnebesnih 9000 voznje sa 5W30. Imali su 4 kantice po 1L 5W30, "mozda i 5 samo da pogledaju". Nisam tip da se Je*em za 200 dinara, ne bih vozio RSa da mi se gace tresu za te pare. Jednostavno trenutna nestasica zeljenog ulja. Sledeci put cu sipati 5W30, a mozda ponovo 10W40, videcemo.
Nadam se da se ne ljutite?
totti piše:Ne znam šta da ti kažem, 1.6 ne drlja ni sa dugačkim filterom :D
Naravno kad ZetecSE nema hidraulicne podizace, on samo tiho pati i struze karike.
van piše:Zetec су квалитетни мотори ,можада су и бољи од N7A, a ти мислиш на zetec SE
Nego sta. Zetec E su maratonci.
