Brzinometar na fokusu 1.6 16v 2001.
Nije mesto za kvarove.
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » utorak, 29. mar. 2011. u 08:44h
Jutros pri dolasku na posao, po kiši, u jednom trenutku mi je kazaljka brzinometra
prestala da radi. Skroz je pala kao da stojim u mestu, a za nekih 30 sekundi je ponovo proradila
a onda je nastavila da radi normalno.
Zna li neko o čemu se radi? Jel neki senzor ili slično ili možda samo trenutna slabost mahine? :wtf:
Verovatno postu nije mesto ovde, ali ne mogu da uđem u kvarovi i popravke.
Poruka: 5701
Re: Brzinometar na fokusu 1.6 16v 2001.
Poruka od popovicvl » utorak, 29. mar. 2011. u 16:18h
To je cest problem tj. stalni problem kod Focusa MK1. Bilo je dosta reci o ovome na forumu.
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » utorak, 29. mar. 2011. u 16:24h
Jel to ima veze sa bombinom ili je nesto drugo?
Da ne tražim po forumu.
zeteks
Poruka: 1298
Poruka od zeteks » utorak, 29. mar. 2011. u 16:32h
probaj ovo:
Ford Focus 2000 - 2001 1.4 1.6 Zetec
Problem: Speedometer fails or jumps erratically.
Solution: A common problem is the cylinder head temperature sensor and ignition cables touching. This will cause a number of electrical gremlins including the speedo, wipers not working, electric mirrors, interior lights coming on etc. The solution is to re-route the cylinder head temperature sensor around the ignition cables and secure in place.
Ford Focus 1.4 1.6 Zetec engine
Problem: Speedo needle jumps when accelerating.
Solution: The probable cause is contact between the electrical supply cable to the cylinder head temperature (CHT) sensor and the ignition lead for the second cylinder. This can create interference and cause the speedo needle to jump about. The solution is to use a cable tie to secure the supply cable of the CHT sensor onto the low pressure line brakcet to prevent contact.
probaj da stavis parce plastike izmedju kabla od svecice i kabla od termodavaca. Nalaze se na poklopcu ventila primetices koji su. Ovaj od termodavaca ide ka levo a od druge svecice ka desno.
Moguci uzroci su i:
- zaprljan senzor brzine kretanja vozila. Nalzali se na menjacu. Treba ga ocistiti i zameniti gumicu, eventualno zameniti novim ako ovo ne pomogne. Radili su neki na internetu to sami i kazu da nije bas pristupacno ali moze da se uradi samostalno.
- hladni lemovi na instrument tabli (kazu isto tipican problem kod nekih godista Focusa)
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » utorak, 29. mar. 2011. u 17:48h
Hvala na odgovoru!!! thumbsuph
Ako još neko zna nešto o ovome - pričajte.
zx3
Poruka: 297
Član foruma od: nedelja, 12. okt. 2008. u 21:02h
Lokacija: Požarevac
Poruka od zx3 » utorak, 29. mar. 2011. u 20:40h
Verovatno ti je akumulator oslabio, to se i meni dešavalo kad je akumulator već bio pri kraju.
Ma samo da je turbo pa nek je i dizel.
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » utorak, 13. sep. 2011. u 08:29h
U poslednje vreme par puta mi je opet pala skazaljka brzine, a desilo mi se i to da mi pokazuje da mi je rezervoar pun, iako je polu prazan...
Jel moguće da je akumulator oslabio?
fancy
Poruka: 2265
Lokacija: 11090
Poruka od fancy » utorak, 13. sep. 2011. u 09:40h
A jel moguće da ti još uvek nisi otišao do servisa da dobiješ tačnu dijagnozu i rešiš to nego filozofiraš nad pogađanjima ljudi koji nisu ni videli tvoj automobil? :D
p.s. dok ga neko stručan ne pogleda, odgovor je vrlo kratak - sve je moguće.
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » utorak, 13. sep. 2011. u 13:04h
Znaš šta sam naučio na ovom forumu....Da pre odlaska kod majstora (ili kako ih ti zoveš servisera, a u Nišu još nisam pronašao dobrog majstora)
prvo dobro izfilozofiram na forumu (čitaj - saznam u čemu je kvar, barem približno).
Razlog? Jer ne bih da prođem kao pojedini članovi koji bespotrebno promene 5-6 stavki na autu,
a ne reše problem sve dok ne odu kod Dragomira...
A do tada bacili silne evriće... sign0007
Poruka: 15311
Poruka od mbole » utorak, 13. sep. 2011. u 13:49h
Ma OK je to, al od Marta do Septembra...
Do sad si mogao i do Dragomira da stignes :)
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » petak, 7. okt. 2011. u 15:36h
Pošto je problem nestao u poslednje vreme, nisam ni pokušavao da ga rešim, ali......
Odem pre par dana kod servisera akumulatora da proverim stanje istog, kad tamo imam šta da vidim...
Izmeri mu on parametre, sve super, ali pita me što imam ovako slab akumulator? Od 45 ampera?
Rekoh, takvog sam kupio i nisam proveravao...On mi kaže da za fokusa trebam makar 55 amprea ili 60 optimalno...,
Inače, sa ovim akumulatorom vozim već 18 000 km i nisam imao većih problema...Mada sada predpostavljam da ovo sa brzinometrom
može da ima veze sa akumulatorom.....
Šta su vaši saveti, jel da vozim i dalje dok ne rikne akumulator ili da odmah kupujem novi?
Serviser mi je rekao da vozim ovako, ali da se nikad ne zna koliko će da traje......
Poruka od totti » petak, 7. okt. 2011. u 16:49h
Za tog Focusa (1.6 benzinac) je dovoljan i od 45 ah.
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » utorak, 1. nov. 2011. u 13:10h
Kaboom1985
Poruka: 2
Član foruma od: četvrtak, 1. dec. 2011. u 21:24h
Poruka od Kaboom1985 » četvrtak, 1. dec. 2011. u 21:37h
Ja imam isti problem kao i ti??? Kupio sam Forda Fokusa 1.6 benzin i isto imam problem sa brzinometrom cas radi cas neradi?!?!?! pa me zanima da li si rijesio problem i sta je bilo.....pozzdrav
milanbil
Poruka: 779
Lokacija: Niš
Poruka od milanbil » sreda, 21. dec. 2011. u 14:41h
Pa nisam ga ni resio... hahahaha
Verovatno bi trebalo zameniti senzor brzine...
