Ovo su opisi tvojih gresaka, ima tu svasta-nesto. Sta ti odgovara ti prihvati, resto odbaci...
P0171
Error Description:
System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. For lean and rich DTCs: Fuel system Excessive fuel pressure. Leaking/contaminated fuel injectors. Leaking fuel pressure regulator. Low fuel pressure or running out of fuel. Vapor recovery system. Induction system: Air leaks after the MAF. Vacuum Leaks. PCV system. Improperly seated engine oil dipstick. EGR system: Leaking gasket. Stuck EGR valve. Leaking diaphragm or EVR. Base Engine: Oil overfill. Cam timing. Cylinder compression. Exhaust leaks before or near the HO2Ss. A SHRTFT-1,2 PID value between -25% to +35% and a LONGFT-1,2 PID value between -35% to +35% is acceptable. Reading beyond these values indicate a failure.
P1131
Error Description
Lack of HO2S-11 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
Opciono:
P1130
Error Description
Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit. Electrical: Short to VPWR in harness or HO2S Water in harness connector Open/Shorted HO2S circuit Corrosion or poor mating terminals and wiring Damaged HO2S Damaged PCM Fuel System: Excessive fuel pressure Leaking/contaminated fuel injectors Leaking fuel pressure regulator Low fuel pressure or running out of fuel Vapor recovery system Induction System: Air leaks after the MAF Vacuum Leaks PCV system Improperly seated engine oil dipstick EGR System: Leaking gasket Stuck EGR valve Leaking diaphragm or EVR Base Engine: Oil overfill Cam timing Cylinder compression Exhaust leaks before or near the HO2S(s) A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
