Ford Focus - zupcanik i znak uzvika
xzy
Poruka: 18
Član foruma od: utorak, 13. avg. 2013. u 09:35h
Poruka od xzy » sreda, 15. jan. 2014. u 08:21h
Ovako, kao sto mozete videti na fotografiji, od skoro se pojavljuje svetlece-crveni simbol zupcanika u cijem centru je znak uzvika. Auto je Focus 1.8 tdci 2006. U pocetku se pojavljivao u sred voznje, i odmah po gasenju/paljenju auta je nestajao. Tako je bilo dva puta, sada ne nestaje. Cini mi se da auto slabije vuce kada je on aktiviran.
Sta moze biti posredi? hvala
Dragomir
Oficijalni serviser
Oficijalni serviser
Poruka: 5503
Lokacija: Avala-BG
Re: Ford Focus - zupcanik i znak uzvika
Poruka od Dragomir » sreda, 15. jan. 2014. u 12:36h
Treba prikaciti na dijagnostiku I viditi sta prijavljuje
xzy
Poruka: 18
Poruka od xzy » sreda, 15. jan. 2014. u 13:34h
Hvala, nasao sam da je to multifunkcionalno upozorenje, i def treba videti sta je tacno posredi.
Evo usput i sta sam nasao ako nekom zatreba, uputstvo kaze ovo:
My guess is that you are talking about a Brake System Warning light.
According to the 2007 Focus manual ( I took a wild generic guess) the light that you have described shows on page 11
And this is what page 11 text says:
--- copy---
Brake system warning light: To
confirm the brake system warning
light is functional, it will
momentarily illuminate when the
ignition is turned to the ON position
when the engine is not running, or in a position between ON and START,
or by applying the parking brake when the ignition is turned to the ON
position. If the brake system warning light does not illuminate at this
time, seek service immediately from your authorized dealer. Illumination
after releasing the parking brake indicates low brake fluid level and the
brake system should be inspected immediately by your authorized dealer.
---end copy---
To confirm my suspicion, please see your manual
If you don't have a manual;
Ford has free download-able manuals online for all of their vehicles from (years)
1996-present
They are in pdf format so they are easy to save to your computer for future reference and print as/if needed.
No subscriptions, fees, personal info, nor registration is needed to use the Ford resource sites!
^^^^ ^^^^ ^^^^ Important for your privacy and security ^^^^ ^^^^ ^^^^ ^^^^
Ford/Motorcraft site:
http://www.motorcraftservice.com/vdirs/r...
Just see to the tab on left that says "Owner Guides" and submit your vehicle Year/Model.
Or
You can also go to the Ford Owners website and do the same!
http://www.ford.com/ownership/
(Occasionally Ford servers go down and the sites are not available, but in that rare occurrence, if you get an error message, you can just try a little later.)
