dijagnostika auta
- speccko
- Poruka: 504
- Lokacija: Vrbnica/Vienna
Re: dijagnostika auta
Obrisao sam sve greske. Stari interfejs je izgleda napravio neki spoj, konfuziju, imao sam ja mislim sve greske koje se mogle upaliti u auto, ako nije bilo preko 30.
https://www.amazon.de/gp/product/B076VP ... UTF8&psc=1
Narucio sam ovaj sa Switch-erom, jes malo skuplji ali vidim vec radili ljudi sa njim i odlucio da kupim aplikaciju FORScan lite za telefon (moraju i ti ljudi od neceg da zive) i odradio posao.
Videcu ovih dana da nakacim preko laptopa, samo prvo da dopunim akumulator, da ne bih napravio jos neko njesra.
Inace, ovaj OBD2 se kaci preko WIFI.
- Poruka: 15143
Switch je jedno, a switchER je nesto sasvim drugo
- Skittles
- Poruka: 106
- Član foruma od: subota, 28. dec. 2019. u 19:57h
Ja sam imao sledeće greške:
===PCM DTC U0101:00-28===
Code: U0101 - Lost Communication with TCM
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===PCM DTC U0151:00-28===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
===PCM DTC U0121:00-28===
Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module A
Status:
===PCM DTC U0155:00-28===
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Status:
===PCM DTC P193D:82-28===
Code: P193D - Cruise Control Multi-Function Input Signal
Additional Fault Symptom:
- Alive/Sequence Counter Incorrect/Not Updated
Status:
===OBDII DTC U0155-C===
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===ABS DTC U0300:00-28===
Code: U0300 - Internal Control Module Software Incompatibility
Status:
Module: Antilock braking system
===ABS DTC C1109:64-68===
Code: C1109 - Vehicle Dynamics Control Switch
- Signal Plausibility Failure
Status:
- Test not complete
Freeze Frame :
-GLOBTIM: 283950018 s - Global real time
-TOTDIST: 0.0 km - Total Distance
-MAINECUV: 12.25 V - Main ECU voltage supply
-OUTTMP: 23 °C - External Temperature From Sensor
===ABS DTC U0140:00-68===
Code: U0140 - Lost Communication With Body Control Module
Status:
- Test not complete
===IPC DTC P0850:62-2C===
Code: P0850 - Park / Neutral Switch Input Circuit
- Signal Compare Failure
===ABS DTC U0401:00-68===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status:
- Test not complete
===ABS DTC U0126:00-28===
Code: U0126 - Lost Communication With Steering Angle Sensor Module
Status:
===RCM DTC U0300:00-28===
Status:
Module: Restraint Control Module
===PSCM DTC U0415:00-08===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
Status:
Module: Power Steering Control Module
Freeze Frame :
-GLOBTIM: 284296309 s - Global real time
-TOTDIST: 159991.0 km - Total Distance
-MAINECUV: 12.00 V - Main ECU voltage supply
-PWR_MODE_KEY: Ignition On - Power Mode Key State
-PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
-SS_TRQ2: 12.4 Nm - Steering Shaft Torque 2
-MOD_SUP_V: 4.80 V - Module Supply Voltage
-PSCM_INT_TEMP: 40 °C - PSCM Internal Temperature
-VSS: 0.0 km/h - Vehicle Speed
-DLA_SED_FD0B_PID: 142 - DL_SED_FD0B_PID
-DLA_NUM_FD0C_PID: -0.02 A - DL_NUM_FD0C_PID
-DLA_NUM_FD0D_PID: 0.00 A - DL_NUM_FD0D_PID
-DLA_NUM_FD0E_PID_1: 0.0 Nm - DL_NUM_FD0E_PID_1
-DLA_NUM_FD0F_PID_1: 0 1/min - DL_NUM_FD0F_PID_1
===PDM DTC U0010:88-2C===
Code: U0010 - Medium Speed CAN Communication Bus
- Bus Off
Status:
- DTC Maturing - Intermittent at Time of Request
Module: Passengers Door Control Unit
===DDM DTC U0010:88-2C===
- Bus Off
Status:
Module: Drivers Door Module
===RFA DTC U3003:62-28===
Code: U3003 - Battery Voltage
Status:
Module: Remote Function Actuator
===IPC DTC U3006:16-28===
Code: U3006 - Control Module Input Power A Circuit / Open
- Circuit Voltage Below Threshold
Status:
Module: Instrument Panel Control Module
___________________________________________________________
Ukratko imao sam SVE greške.
Uglavnom je izgubljena komunikacija sa BCM i to bilo al sada nije.
Uzeo sam i obrisao sam ih sve, pa ćemo videti posle malo vožnje šta je stvarno problem (pojaviće se ponovo) a šta je samo ostalo zapisano.
Ono šta me zanima je da li neko može da zaključi šta je moglo da se desi automobilu za sve ove greške?
Da li govore nešto?
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
- Test not complete
Freeze Frame :
Status:
- Test not complete
Status:
- Test not complete
Status:
Status:
Status:
Freeze Frame :
- Bus Off
Status:
- Bus Off
Status:
Status:
Status:
Da li govore nešto?
- Poruka: 15143
Ne bih da se ponavljam ko baba... al .... prva meta: lose zice i/ili losi/labavi konektori ka nekom od racunara u autu
- speccko
- Poruka: 504
Sa switch-em
Razumemo se sad. Thx
To je kad sviram... pa koristim engleski sto pise switch a da me pita covek sto.
Sto se tice ovih gresaka, kakav OBD koristis? Cini mi se da mi se pojavilo tipa kao one tvoje prve 3 - kad nije hteo lepo da ucita, pa sam ponovio citanje.
- speccko
- Poruka: 504
Citajuci neke strane forume naisao sam na mogucnost aktiviranja spustanja retrovizora prilikom ubacivanja u rikverc.
Koliko videh, prvo se pritisne /aktivira levi/desni retrovizor i kad se ubaci u R on se spusti
Jel imao neko iskustva slicnih?
Drugo takodje, ali nisam siguran da li se novi firmver ucita, da se promeni deo ove instrument table
- speccko
- Poruka: 504
Update- za spustanje retrovizora prilikom ubacivanja u rikverc mora da se imaju retrovizori sa memorijom.
- FrenkyVu
- Poruka: 68
- Član foruma od: sreda, 27. nov. 2013. u 21:14h
- Lokacija: Vukovar
Da se nadovežem... Ako si ikad merio snagu auta u vožnji koristeći Torque nikad ne izbaci tačno, bar meni, uvek manje. Meni izbaci cca 60+ks (po papirima je 125ks).
Koliko sam skontao Torque računa G silu i uz postavke koje uneseš u auto (masa u kg - ona varira od vozača, količine goriva, putnici... to ti moraš podesiti u profilu automobila) tako da to što ispiše Torque nije tačna brojka.
Jedino što po meni ima smisla u ovom videu je da se vidi povećanje - bitno je da su brojke iz druge vožnje veće nego iz prve.
Pravi test bi bio Dyno test.
Da li je lik uspeo povećati snagu auta to ne znam. Možda su prva i druga vožnja iz dva različita auta pa su zato brojke veće.
Najbolje bi bilo da neko ko ima ovakav auto testira ovaj jednostavni chiptuning pa da potvrdi
- Poruka: 10001
- Nedeljkovic
- Poruka: 4741
- Lokacija: Lazarevac
Forscan je free samo moras da skidas novu licencu sa sajta kada ti istekne
- Poruka: 9969
Daj link
- Poruka: 10001
- Poruka: 9969
Kabal ili blue?
- Poruka: 10001
Ja sam uzeo na kabal zbog elm config-a
- Poruka: 9969
Uzeo kabal
- Aca06
- Poruka: 3178
- Lokacija: Surčin
Da li radi na Win 10?
Vidim u opisu da radi na XP i Win 7(32bit).
- sarabo
- Poruka: 2172
trebalo bi da radi, ja kad sam uzeo ELM na BT isto je pisalo da radi na win7 i XP, ali radi i na W10
Fiesta 1.8 d ( 1997 )
- Djole
- Master of Tanjirača
- Poruka: 4954
- Lokacija: Valjevo
Radi.
Srecko_Bgd
- Poruka: 11
- Član foruma od: subota, 6. mar. 2021. u 10:28h
Pozdrav drugari,imam focusa mk3.5 2015 1.5 tdci,ukljicio sam onu glupost MyKey a kako imam samo jedan kljuc sada je ne mogu iskljuciti. Jer se to moze iskljuciti preko dijagnostike? Svaka preporuka za resenje dobrodosla
- Aca06
- Poruka: 3178
- Lokacija: Surčin
- Poruka: 10001
Imam dva problema pri koriscenju Elmconfig-a
Prvi - ne mogu da iscitam sve "tabove" zbog brzine komunikacije, trazi mi vecu brzinu, a kada nju izaberem uopste ne mogu da startujem program
Drugi - ugasio sam zvucno upozorenje i sijalicu na tabli da pojas nije vezan, ali tabla ne hebe 2%, sija i dalje dok se ne vezem
Da li se neko susretao sa necim od ovoga?
- Nedeljkovic
- Poruka: 4741
Koliko tabova ne mozes da iscitas, na mk2 mislim da i ne mogu 3-4 taba da se iscitaju. Je l imas prekidac za brzi i spori CAN?
Pistalicu ugasi rucno, das kontakt i da l 5 ili 6 puta zabodes i izvadis vozacev pojas, cuces zvuk za potvrdu
- Poruka: 9969
9 puta
- Poruka: 10001
Imam prekidac. Provericu tacno koji su tabovi.
Pistanje sam ugasio preko elm-a, ali lampicu na tabli ne mogu.
- Nedeljkovic
- Poruka: 4741
To bi trebalo da buds u HEC modulu, pogledaj da li imas 'seatbelst not fastened' ili tako nesto
Sto se tice prekidaca imas module koji su vezani na brzi kan i spori kan i u zavisnosti od toga kada im pristupas trazi ti da prekidac stavis u odgovarajuci polozaj. U par modula se ne moze upisivati kod Focusa mk2 ali se mogu iscitati
