Kôd: Označi sav tekst
http://img222.imageshack.us/f/84513581.jpg
prevod:B+ goes to the battery (i.e 12V 'on' all the time - this supplies the amp most of it's power) V+ goes to the headunit, switched 12v (it tells the amp when to turn on. Alternatively you could wire it to the 'accessory' 12v)
is 'con' right beside B+ and V+? If it is, I would probably assume it is the ground. Maybe it's actually 'com' i.e 'common' = ground
B + ide na akumulator (tJ. 12V stalni napon) V + ide u cd plejer, pobuda 12V (to govori pojačalu da se uključi kada uključite cd plejer ". pribor '12V)
'con' odmah pored B + i V +? Ako Jeste, verovatno da Je uzemljenje. moguce da je 'com', iz izraza 'common' = tla
