pitanje vezano za gorivo
- kazalajt
- Poruka: 291
- Član foruma od: utorak, 16. feb. 2010. u 22:54h
cuo sam jednu neobicnu stvar vezanu za automobile koji koriste super (MB95).
navodno na 2~3 rezervoara supera (MB95) treba sipati i 1 rezervoar bezolovnog (BMB95) kako bi se malo motor procistio i "odmastio" jer je MB95 masniji od BMB95?
sta vi mislite o ovome , tj jel neko cuo za ovako nesto ranije????
hvala
hvala
- Poruka: 8421
Re: pitanje vezano za gorivo
Mislim da nema potrebe. Dok smo imali Citroena GS koji je trošio Super nikad nismo točili bezolovni. I nije bilo problema.
To nikako, napravićeš sebi štetu:
Why Can’t Older Engines Use Unleaded Fuel?
By far the biggest problem arising from using unleaded fuel on older engines is a condition known as valve seat recession (VSR). Without the protective lead coating (previously provided by leaded fuel) on the exhaust valve seats, the intense heat (650°C) and hammering effect of the valves opening and closing, causes iron deposits from the valve seat to become micro-welded to the valve edge. Left unchecked, this continual tearing away of metal particles will result in the exhaust valve digging a deeper and deeper hole for itself into the cylinder head. Eventually, and often within only a few thousand miles, the engine will breakdown completely and it will require an expensive overhaul. To combat this problem, modern petrol engines have special hardened valve seats which can withstand this harsh environment.
- Neša
- Poruka: 5066
- Lokacija: Прокупље
Od 1.jula u Srbiji se ne prodaje vise olovni benzin. Nema stete kad se koristi bezolovni benzin u motorima koja trose super,neko pominje aditive za oldtajmere navodno jer olovo podmazuje ventile i sedista ali do sada u praksi nije bilo problema. Vece stete pravi plin od bezolovnog
Plin ne pravi nikakve štete na motorima koji idu na "super" (pogotovo ne na onim koji idu na benzin od 86 oktana, njima plin i prija, troša ga isto kao i benzina i idu isto), ali su odavno dokazali preko da bezolovni pravi probleme na motorima starije konstrukcije.
Inače tekst koji sam citirao je objavio najpoznatiji časopis koji se bavi tjuniranjem bajatijih Fordova, ako ne verujemo njima i ljudima koji već decenijama održavaju takva vozila u našim uslovima...
Ugrubo rečeno pričamo o motorima pre '80-te godine.
- kazalajt
- Poruka: 291
OK ljudi hvala u svakom slucaju, to mi rece kolega da je negde cuo za tu varijantu kao cisto onako malo da se ponekad promeni ne da se za stalno promeni. al hvala na detaljima
pozdrav
pozdrav
Nešto sam zanimljvo našao na ovu temu:
Dalje iz tog teksta:
Ovde zapravo piše da motori koji su napraljeni za olovni, a koji se voze na bezolovni, za njih je preporučeno da se na svaka tri rezervoara bezolovnog sipa jedan pun olovni, tako da je moguće da je tvoj kolega malo pogrešno čuo.Firstly, all Capri engines, except the turbo equipped models, will run on unleaded petrol provided every fourth tankful is 4 star leaded. This is possible due to a phenomenon called 'lead memory'. Lead from the 4 star actually stays within the combustion chamber and on the valve seat for some time. If unleaded is to be used, the second problem of pinking must be overcome, and this is done by retarding the ignition timing...
If you own a 3 litre Capri, you could have hardened valve seats fitted to your existing cylinder heads (as you could with any Capri engine), and this would also solve the problem, apart from necessary timing adjustment that will be required. It has been reported, however, that under certain circumstances some valve seat inserts have fallen out into the combustion chamber while the engine has been running, which resulted in engine destruction!
There does seem to be a very easy, relatively cheap and simple solution to this problem, in the form of a Catalyst that is simply added to the fuel tank. There are two companies marketing similar products, both of which have been running advertisements in the car magazines. One is called 'Broquet Fuel catalyst', and is marketed by David Lock and Associates, and the other is called 'The Fuel Cat', and is marketed by a company of the same name.
They both claim to allow a 'Lead only' engine to run continuously on unleaded petrol without the risk of engine damage and without having to retard the ignition timing. Sounds too good to be true, I hear you say. I too was filled with scepticism, so I contacted both companies to obtain further information.
I wrote to David Lock first to gain information on 'Broquet'. David then rang me and we spoke at great length about what 'Broquet' is and how it does what he claims. It would appear that it was developed during the Second World War to allow Hurricane aircraft, on loan to the Russians, to run on the very poor quality fuel they had at the time, and this it did very successfully. More recently, it has been used by the Civil Service Motoring Association since 1989, and collectively their members have covered in excess of 200 million miles using Broquet with no reports of any engine damage from any of their 10,000 members.
Basically, it consists of a mesh bag filled with predominantly tin pellets, which is simply dropped into the fuel tank. This causes a catalytic reaction which causes it to change the properties of the fuel, resulting in much more efficient burning, and this in turn means that the combustion temperature is significantly lowered to below a safe level for 'Lead only' engines to operate. This more efficient burning also gives improved fuel economy, more power and less carbon build up in the cylinders, so a cleaner engine. Broquet also offer an 'Engine Damage Warranty' that states that if an engine is damaged by the use of their product, it will be repaired or replaced at their cost.
- Boris88
- Poruka: 1693
pa nista ja cu izgleda morati od prvog jula da stavim 200,300grama olova u rezervoar pa da tocim bezolovni thumbdown
rust is not a crime
- Poruka: 8421
Napuni ga olovom.
- kazalajt
- Poruka: 291
ma daj bre kako mogu debili da ukinu koriscenje neke vrste goriva koja se i dalje koristi i to fino???????
treba ih zapaliti!!!!!! war
debili
debili
- Poruka: 21599
Ko još koristi olovni benzin ?
Sva ta matora kola odavno već idu na plin.
A oni koji ne idu a imaju imalo mozga će i preći uskoro, ipak je to investicija koja samu sebe isplati posle par meseci, može i na rate da se uzme...
- Poruka: 418
- Član foruma od: petak, 10. okt. 2008. u 13:12h
Nisi jediniBoris88 piše:pa nista ja cu izgleda morati od prvog jula da stavim 200,300grama olova u rezervoar pa da tocim bezolovni thumbdown
- Neša
- Poruka: 5066
Ma kakvo olovo ljudi,pa to je izbaceno u drugim zemljama jos pre 20g i vise,a mi trujemo decu,ljude,biljke i zivotinje...
Ja neznam i do sada sta se cekalo?
Postoje aditivi koji se dodaju i to ne tako cesto,tako da bez brige
- Boris88
- Poruka: 1693
pre 20 godina je u vecini drugih zemalja izbacen i bus kao prevozno sredstvo,cak i rumuni imaju metro a smeta im moj fordic koji cadi kao lud gears e pa ko jebe zemlju koja pravi jugice vec 30 godina i nista ne menja,osim sto su ga cuningovali za primer sta ne raditi autu mechanic
rust is not a crime
- kazalajt
- Poruka: 291
e ljudi citao sam u autodata programu da moj ford moze da ide i na olovni i na bezolovni bez frke thumbup
pise : suitable for unleaded fuel : Yes
- Neša
- Poruka: 5066
Svi fordovi benzinci posle 85.g mogu da koriste samo bezolovni benzin
- kazalajt
- Poruka: 291
ma extra je stvarno
Naravno da može da ide, nije to voda pa da ne ide, ali će biti posledica.
- kazalajt
- Poruka: 291
kakvih posledica? :-|
- Neša
- Poruka: 5066
Mislio sam da mogu da se voze na bezolovni bez posledica posle 85.g. Sedista ventila su napravljena od drugacije legure metala...
Drugo,NIS je izjavio da je nas bezolovni vec tretiran aditivima u procesu proizvodnje tako da nece biti problema za stara vozila.
- ace1
- Avenger from the past
- Poruka: 1983
@boris88 imas pivo od mene za ovaj post
It is 1971
It is 1971
