Taunus GT300 v6 2.9 Project by VBT
Cika Dule
Poruka: 443
Član foruma od: sreda, 5. maj 2010. u 12:52h
Lokacija: Zemun
Re: Taunus GT300 v6 2.9 Project by VBT
Poruka od Cika Dule » nedelja, 18. sep. 2011. u 17:44h
Koliko se snage otprilike moze izvucu tj ocekivati sa ugradnjom istog. Vidim da na datom sajtu pisu 40 + posto...
peca
Poruka: 2469
Lokacija: Beograd - Mirijevo
Poruka od peca » nedelja, 18. sep. 2011. u 18:19h
Ja sam mislio da sam postavio link za m62...
Iskopirano sa http://www.mx6.com/forums/2g-mx6-forced ... -info.html :
I've had a few emails recently about how I went about building my sc and what was involved, so I'll provide some info about it. This write up isn't all inclusive, but will give person's interested an idea of what's involved in the build. It's alot cheaper than a turbo, I did mine for around $650 and that was for everything, sc, fp, millenia injectors, fmu (initially), etc. and great for a low boost application, up to 9lbs. If you're looking for more boost, I suggest a turbo. The electric clutch is cool also, allowing you to drive totally n/a and then be boosted with the flick of a switch, literally.
milivojekg
Poruka: 252
Član foruma od: subota, 27. mar. 2010. u 18:08h
Lokacija: Kragujevac
Poruka od milivojekg » nedelja, 18. sep. 2011. u 23:19h
Hoces li koristiti intercooler?
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » ponedeljak, 19. sep. 2011. u 00:20h
Naravno ..njega i cekam ..inace bih odavno povezao sve... mrgreen
inace Peco hvala za info... thumbsuph
SlikaSlikaSlikaSlika
peca
Poruka: 2469
Poruka od peca » ponedeljak, 19. sep. 2011. u 00:49h
Nema na čemu thumbsuph ...
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » ponedeljak, 12. mar. 2012. u 00:39h
Evo malo da skinem prasinu sa teme...polako se vreme prolepsava pa smo odlucili da nastavimo sa radovima...
intercooler je stigao i nadjeno mu je mesto...
predihtovan usis i dizne...muka je bio naci tu neku vrstu kapica za dizne.. :blink:
ofarbani su nanovo usis i ova precka u crvenu boju...trebao bi i kompresor da pocrveni... :D
izbacen je vis ventil sa usisa i napravljeni cepovi...
sad treba otici u nabavku i pokupovati cevi za usis i ukrojiti sve to...bice slika i kad to dodje na red...
Shomy_ksh
Počasni Čak Noris
Poruka: 3609
Lokacija: Krusevac
Poruka od Shomy_ksh » ponedeljak, 12. mar. 2012. u 00:53h
koliko je izasao IC ako nije tajna ? i sta sve treba da uradis da bi ga spojio (mislim na elektroniku, tj da li nesto treba od senzora da se menja doda ... ) ? :)
Ford Fiesta DuraTorQ 1,4TDCi
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » ponedeljak, 12. mar. 2012. u 01:05h
Izasao je oko 80eura...a ne treba mi nista od elektronike..samo reporgramiraje ecu zbog nadpritiska...
Turbo Force
Rostilj majstor
Poruka: 386
Član foruma od: sreda, 15. okt. 2008. u 16:14h
Lokacija: Beograd/Vozdovac
Poruka od Turbo Force » ponedeljak, 12. mar. 2012. u 02:20h
Mislim da je ovo mali IC za tu kubikazu, zna li se koliko puni kompresor?
BokiRS
Neizleciv
Neizleciv
Poruka: 4457
Poruka od BokiRS » ponedeljak, 12. mar. 2012. u 07:36h
Nije mali ne brini.
Bosko pozuri sa radovima, nestrpljivi smo.
Zapostavljas Escorta, jel bar spao sneg sa njega? :D
Chip tuning za Ford-ove
viewtopic.php?f=94&t=19067
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » ponedeljak, 12. mar. 2012. u 23:53h
meni treba 0.5 bara...mislim daj je IC sasvim dovoljno velik..nije to velik pritisak..trebalo bi da bude ok..
E jeste spao je sneg sa escorta...cekam da mi stigne chip i map od 3bara....pa cu da se angazujem oko njega..trebam da promenim ulje i da ga registrujem...
BokiRS
Neizleciv
Neizleciv
Poruka: 4457
Poruka od BokiRS » utorak, 13. mar. 2012. u 07:08h
I ja mislim da je IC sasvim dovoljan.
Super, kad to stigne moras opet da me provozas thumbsuph
fordst
Poruka: 204
Član foruma od: ponedeljak, 29. nov. 2010. u 16:35h
Lokacija: Skopje-Makedonija
Poruka od fordst » utorak, 13. mar. 2012. u 13:56h
bossko77 piše:Izasao je oko 80eura...a ne treba mi nista od elektronike..samo reporgramiraje ecu zbog nadpritiska...
Jel sam radis reprogramiranje ecu-a? :)
Poruka: 9042
Poruka od van » utorak, 13. mar. 2012. u 14:24h
Човек нема фабрички , него custom ecu , који треба да се споји са било којим рачунаром , да се подигне програм и промене податци по табелама и изабере адекватан режим рада .
Једино што треба негде да се провере да ли су прави податци , тј . да се премери .
Цео систем је и осмишљен да подржи силне модификације , и да може да контролише све и свашта и да је читање и упис података лак и доступан .
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » utorak, 13. mar. 2012. u 22:24h
fordst piše:
a sam ..zasad cu samo postojecu mapu goriva linearno podici za 1 bar..shodno tome i tabelu paljenja...imam dosta tabela za slicne motore pa cu odatle malo iskombinovati podatke...ali u svakom slucaju auto ce ici na mapiranje kod profesionalca kad se sve zavrsi...
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » petak, 23. mar. 2012. u 17:39h
pocelo je igranje sa cevima od usisa,,ovako izgleda....stize jos slika kad se vratim kuci i vidim sta je Vuja uradio.. :D
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » utorak, 27. mar. 2012. u 01:50h
evo jos slika...
ostale su jos neke sitnice da se uklope i mogu cevi da se nose na varenje i poliranje,,,
BokiRS
Neizleciv
Neizleciv
Poruka: 4457
Poruka od BokiRS » utorak, 27. mar. 2012. u 08:23h
Jedva cekam da se sve zavrsi pa da vidimo kako ce da ide.
Mnogo su mi interesantni ti kompresori
Poruka: 7621
Poruka od dax92 » utorak, 27. mar. 2012. u 10:19h
ST sa kompresorom- zanimljivo! mrgreen
BokiRS
Neizleciv
Neizleciv
Poruka: 4457
Poruka od BokiRS » utorak, 27. mar. 2012. u 10:31h
I ja kazem :D
Poruka: 9042
Poruka od van » utorak, 27. mar. 2012. u 10:37h
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » sreda, 28. mar. 2012. u 00:17h
BokiRS piše:Jedva cekam da se sve zavrsi pa da vidimo kako ce da ide.
kome kazes.... thumbsuph
RS_cabrio
Ljubitelj životinja
Poruka: 3350
Poruka od RS_cabrio » sreda, 28. mar. 2012. u 00:23h
gde ste uzeli ovaj turbo kit?
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » sreda, 28. mar. 2012. u 00:29h
nismo uzeli...pravili... ;)
RS_cabrio
Ljubitelj životinja
Poruka: 3350
Poruka od RS_cabrio » sreda, 28. mar. 2012. u 00:39h
:doh:
