Moj Ford Mondeo 2.0 TDCi 2003 karavan by noćni soko
noćni soko
Poruka: 8
Član foruma od: utorak, 25. jul 2017. u 17:09h
Poruka od noćni soko » utorak, 25. jul 2017. u 18:19h
Pozdrav,
Kupio sam mog Forda prošlog Novembra a uvezen prošlo leto.
Prethodni vlasnik mu je odmah uradio set kvačila i zamajac a ja pumpu za gorivo i dizne.
Sada dolazi mali servis a i mislim da me kompresor od klime zeza, moram da idem kod majstora. :/
Ford Mondeo TDCi 2.0 karavan
2003 god, crna metalik.
Evo i slika :)
Slika Slika Slika
Slika Slika Slika
Slika Slika Slika
noćni soko
Poruka: 8
Re: Moj Ford Mondeo 2.0 TDCi 2003 karavan
Poruka od noćni soko » četvrtak, 27. jul 2017. u 15:47h
Info sa Ford Etisa:
Primary Features
Build Date: 17.06.2003
Vehicle Line: Mondeo 2001-2007
Body Style: 4 Door Estate
Version: Series 40
Engine: 2.0L Duratorq DI CR (130PS)
Transmission: 6 Speed Manual Transaxle - MMT6
Drive: LHD FWD
Axle Ratio: 4.071/2.850
Emission: 2000 EEC (EEC 7)
Air Conditioning: Automatic Air Conditioning
Territory: (+)"NL"
Paint: Panther Black (Metallic)
Interior Colour: Ebony Interior
Interior Fabric: Tria
Genk Plant Build
Marketing Flex Prep Pack 4
Marketing Flex Prep Pack 10
Marketing Level 1
Less Dress Up RSO
(-) SVP
Exterior Paint - Metallic
Spare Wheel Warning Sticker
Power Front Windows One Touch Down
Power Rear Window One Shot Up/Down
With Heated Windscreen
Roof Rack Without Crossbars
Electric Operated Rear View Mirror
Dual Power Heated Fold Back Mirror
With Body Coloured Exterior Mirror
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Passenger Seat Belt Minder
Less Child Integrated Seat
With Driver 2 Way Pwr.Seat Adjuster
With Pass 2 Way Manual Seat Adjust
Less Trailer Coupling
With Leather Gear Shift Knob
With Door Entry Remote Control Unit
With Rear Window Wiper/Washer
With Automatic Windscreen Wiper
With Heated Washer Jet
With Headlamp Washer/Wiper
Air Curtain Restraint LH
Air Curtain Restraint RH
Deployable Anti-W'Lash Restr
With Smart Drivers Airbag Restraint
With Smart Passngr Airbag Restraint
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
Spare Wheel - Mini Steel
With Standard Rear Shock Absorbers
16 X 6.5 5 Spoke Alloy Wheel
205/55VR-16 BSW Tyre
Limited Service Mini Spare Tyre
Locking Wheel Nuts
With Standard Suspension
With Brake Emergency Assist
4 Wheel Anti-Lock Braking System
Filter Cowl Intake - Odour
With Electrically Enhanced Heater
With Speed Control
With Symbol Fuel Computer
Less Reverse Proximity Sensor
Less Radio Pre-Equipment Pack
Less Auxiliary Compact Disc Player
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 1
ICE Feature Pack 49
Less Diversity Antenna
With 4 Speakers
Less Family Entertainment System
With Column Stalk Radio Controls
With Front Fog Lamps
With Automatic Headlamp On/Off
With Instrument Panel Dimmer Switch
Poruka: 2810
Poruka od Lale » četvrtak, 27. jul 2017. u 21:24h
Ima godina, ali lepo izgleda.
Da li je auto ispunio tvoja očekivanja?
Nikola312
Poruka: 1148
Poruka od Nikola312 » petak, 28. jul 2017. u 09:34h
Očigledno nije, eno ga u oglasima :)
Stvarno lepo izgleda Mondiša, godine su samo broj :)
noćni soko
Poruka: 8
Poruka od noćni soko » nedelja, 30. jul 2017. u 08:31h
Lale piše:Ima godina, ali lepo izgleda.
Za sada jeste i više Slika kada sam kupovao auto nisam ni gledao Ford a onda sam naišao na ovog i ljubav na prvi pogled Slika
Nikola312 piše:Očigledno nije, eno ga u oglasima :)
E razlog prodaje je jer se spremam za kruzer da sljakam pa mi treba novaca ali, cčim zaradim stiže novi Slika
Sent from my Lenovo S1La40 using Tapatalk
Poslednja izmena: FM III, na dan nedelja, 30. jul 2017. u 14:20h. Ukupno izmenjeno 1 put.
