ford focus mk2 benzin ili dizel
kekic91
Poruka: 1019
Lokacija: Žagubica
Re: ford focus mk2 benzin ili dizel
Poruka od kekic91 » ponedeljak, 5. mar. 2018. u 15:46h
D900 koliko sam video je nista u sustini e ali E510 vec moze biti Throttle Position Sensor error ili jedan lik kaze da mu prijavljuje menjac. E sad svi postovi su rekli da fokus nece da im upali i medju ostalim kodovima bio je i E510
EDIT nasao
The dash display Code E510 means DTC U2510,
U2510 - Invalid security data received from powertrain ECU (PCM)
There are a few possible causes for this, from the Instrument Cluster (IC), through the wiring (CAN bus connections), to the PCM. Possibly even the PATS sensing coil around the ignition lock barrel, or its connections.
I guess your car is a Mk2a Focus. If so there should be some big connectors just in front of the passenger door, under the plastic trim panels. The trim just unclips, starting from the middle of the bottom of the door, after pushing off the door seal rubber. I would check those for corrosion or damage. Also the big connector built in to the Engine bay fuse box. The CAN bus passes through these connectors.
There is also a 3A fuse in the engine bay fuse box (F30) that can cause problems like this.
A powerful Ford specific diagnostic system like Forscan might yield some more codes and data that could help narrow the problem down. Also there is a simple resistance test that will tell if the main CAN bus is intact from PCM to IC:
Stick a couple of suitable probes (un-bent paper clips can work quite well) in the diagnostic connector pins 6-14, put a DMM across the pair on voltage range, turn ignition on, note reading, turn ignition off, wait till voltage drops to zero (+/- 1 or 2 mV), switch to resistance range to check for 60 ohms.
It should be stable at close to 60 ohms, any deviations would indicate a problem.
If 60 ohms, try tapping and moving various suspects, eg the fascia around the IC, the connector by the front door sill, the connector in the engine bay fuse box, and maybe the PCM. Look for any deviations. (IC = Instrument Cluster)
If not 60 ohms, disconnect the engine bay fuse box big connector, see if reading goes up. If it does, then IC is the fault, if not then PCM may be the fault.
If your car was a 2006 Focus, I would say it was the IC, as this is a very common fault on these. But for 2011, it would be a bit early to blame the IC without further tests. If it is the IC, there are companies offering to repair them for about £100. A Ford dealer would charge over £800 for one!
I can give more info on Forscan, wiring details, and repair options, if of any use.
tika
Poruka: 286
Lokacija: Šumadija
Poruka od tika » ponedeljak, 5. mar. 2018. u 19:53h
D900 se najverovatnije odnosi na nepravilno otkačinjanje OBD adaptera.
Poruka: 15273
Poruka od mbole » ponedeljak, 5. mar. 2018. u 22:44h
Prilikom vracanja kilomeraze :)
AleksVrsac
Poruka: 42
Član foruma od: četvrtak, 8. mar. 2018. u 22:47h
Lokacija: Vrsac
Poruka od AleksVrsac » petak, 9. mar. 2018. u 21:26h
Danas sam bas gledao oglas,tj pre par sati. I sta se na kraju zakljucilo,vredi li ga uzimati i koliko jos love treba da se ulozi? Pitam ljude koji su ga videli uzivo i pricali sa prodavcem.
Ono si sto radis,ne sto govoris da jesi...
duratecHE
Poruka: 4277
Lokacija: Gornji Milanovac
Poruka od duratecHE » petak, 9. mar. 2018. u 23:13h
Danas nije bio na placu, prolazio sam 2 puta tuda, možda je prodat
VUK ZEMUN
Poruka: 31
Član foruma od: sreda, 21. feb. 2018. u 18:55h
Poruka od VUK ZEMUN » petak, 6. apr. 2018. u 18:29h
Vratio ga na oglasu........
duratecHE
Poruka: 4277
Poruka od duratecHE » petak, 6. apr. 2018. u 19:15h
Da juče
Sutra idem da gledam nekog mk1 kod njega pa ću pitam šta je bilo sa ovim
VUK ZEMUN
Poruka: 31
Poruka od VUK ZEMUN » subota, 7. apr. 2018. u 09:51h
Ok
duratecHE
Poruka: 4277
Poruka od duratecHE » subota, 7. apr. 2018. u 15:33h
Sredio ovo na gepeku i vratima...
Mada se na vratima vidi, moglo je i bolje
VUK ZEMUN
Poruka: 31
Poruka od VUK ZEMUN » ponedeljak, 9. apr. 2018. u 11:41h
https://www.polovniautomobili.com/putni ... ....zagreo sam se za ovaj automobil....Sta mislite i da li postoji neko ko je blizu, da prenese neke informacije........Veoma sam ozbiljan...
shix
Poruka: 342
Član foruma od: nedelja, 23. mar. 2014. u 18:44h
Lokacija: Aleksinac
Poruka od shix » ponedeljak, 9. apr. 2018. u 12:44h
Nisi dobro iskopirao link. Otvara naslovnu stranu.
VUK ZEMUN
Poruka: 31
Poruka od VUK ZEMUN » ponedeljak, 9. apr. 2018. u 13:30h
Poruka: 10007
Poruka od macaneli » ponedeljak, 9. apr. 2018. u 13:34h
Jos nisi kupio auto????
VUK ZEMUN
Poruka: 31
Poruka od VUK ZEMUN » utorak, 10. apr. 2018. u 16:59h
cekicko Ne....
Poslednja izmena: FM III, na dan utorak, 10. apr. 2018. u 17:02h. Ukupno izmenjeno 1 put.
Razlog: smajlije stavljaj bez linkovanja
Poruka: 6712
Poruka od vidovac » utorak, 10. apr. 2018. u 19:50h
Dodji da ti.prodam auto
polaris
Poruka: 1091
Poruka od polaris » utorak, 10. apr. 2018. u 20:34h
:D :D :D
A zasto ne vidis ovog,jeste nije Mk1,ali odlican https://www.fordclubserbia.org/forum/vi ... 79&t=29535
Ili ovog slican je sa Mk2 https://www.fordclubserbia.org/forum/vi ... 79&t=28837
Focus Mk3 karavan 2.0 TDCI
Poruka: 4761
Poruka od Nedeljkovic » utorak, 10. apr. 2018. u 20:52h
Ovaj u Kragujevcu ima top cenu za restyle, nece dugo stajati na oglasima ako valja. Pritom ako je kupljen ovde verovatno da postoji servisna istorija do nekog trenutka
VUK ZEMUN
Poruka: 31
Poruka od VUK ZEMUN » utorak, 10. apr. 2018. u 23:08h
uvezen iz francuske.....naplacen kompezacijom od neke gradjevinske firme.....cena mu je 2800 + pdv, jer vlasnik auta je firma....
Poruka: 4761
Poruka od Nedeljkovic » sreda, 11. apr. 2018. u 02:08h
Pa ubedljivo je najjeftinije restyle na oglasima, ako ti se svidja idi i pogledaj, nece ti on dugo stajati ako valja
VUK ZEMUN
Poruka: 31
Poruka od VUK ZEMUN » sreda, 11. apr. 2018. u 22:35h
sta mislite da li je ovaj neka prevara...
https://www.polovniautomobili.com/putni ... ford-focus
Nikola312
Poruka: 1148
Poruka od Nikola312 » sreda, 11. apr. 2018. u 22:45h
Što bi bio prevara, ovaj će da izađe oko 3000 bez registracije. Servis, registracija, gume, aku, ode na 4000 dok si rek'o čajno pecivo s kakao prelivom.
Poruka: 6712
Poruka od vidovac » sreda, 11. apr. 2018. u 22:58h
Mnogo su mu nesto dugmici oguljeni za ovu kilometrazu
The Punisher
Poruka: 230
Član foruma od: četvrtak, 2. sep. 2010. u 08:31h
Poruka od The Punisher » sreda, 11. apr. 2018. u 23:31h
VUK ZEMUN piše:sta mislite da li je ovaj neka prevara...
"može da se carini" meni se čini da je ovo cena bez carine
Poruka: 21876
Poruka od Markedjani » sreda, 11. apr. 2018. u 23:38h
Piše lepo... strane tablice.
Tako da nisu plaćene dažbine.
Poruka: 4761
Poruka od Nedeljkovic » četvrtak, 12. apr. 2018. u 00:20h
vidovac piše:Mnogo su mu nesto dugmici oguljeni za ovu kilometrazu
Klasican problem kod te serije dugmica, nista cudno pogotovu ako je auto stajao cesto na suncu i ako je prskana neka hemija po njima pri pranju
