Dodge Charger 1973g
Iliti uljezi foruma :)
shone190
Poruka: 438
Član foruma od: petak, 24. okt. 2008. u 22:36h
Re: Dodge Charger 1973g
Poruka od shone190 » četvrtak, 19. jun 2014. u 18:51h
Danas se porucuje prava stvar za Charger, 493CID (8100ccm) Crate engine, 525KS i 800Nm :)
HP & Torque: 525 HP / 590 FT LBS
Aluminum Heads
Forged Pistons
Flat Tappet Cam
Forged Crank
Part #: BPC4931CT
Block:
Seasoned 440 block
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
New forged steel crankshaft
Forged pistons
Forged rods
Hastings Moly rings
Balanced rotating assembly
Melling high volume oil pump
Flat tappet hydraulic lifter camshaft
Heavy duty double roller timing set
Cylinder Heads:
Aluminum cylinder heads, 80cc chamber
Cam Specs:
Cam Type: Flat Tappet
.545 Intake .545 Exhaust
241 Intake / 247 Exhaust duration
@ .050
Ignition Timing:
34 degrees at 4000 RPM
Also Includes:
Valve covers, oil pan and timing cover
Brass freeze plugs
Dyno test results shipped with engine
Warranty:
30 month / 50,000 mile
Naravno, uz motor dolazi jos i brdo drugih delova (kompletan izduv, karburator, kablovi, vodena pumpa, pumpa goriva, prednje felne 8J, set za reparaciju menjaca...) ali motor je najbitniji od svega :)
Nadam se da ce kroz koji mesec sve stici, pa da se polako pakuje.
Dodge Charger 1973 8.1l, Golf 4 TDI 4Motion, Chevrolet Corvette C4 5.7l
Poruka: 6106
Poruka od Daniel » četvrtak, 19. jun 2014. u 21:38h
Da li ti mene zajebavas da si za tu zver narucio drugi motor? Zar ovaj nije neki nasviran motor sa boga oca konja? Bar se tako secam da si rekao kad si kupio auto :)
shone190
Poruka: 438
Poruka od shone190 » četvrtak, 19. jun 2014. u 22:18h
Uvek moze bolje i vise, pa zasto da ne :)
Poruka: 5925
Poruka od FiestaBG87 » četvrtak, 19. jun 2014. u 22:23h
Aj po Srpski, koliko ce to biti jace od tog sto je vec u autu? :)
Poruka: 6106
Poruka od Daniel » četvrtak, 19. jun 2014. u 22:38h
@shone, naravno al je pitanje da li mu treba jos snage? Jel bio auto trom? :)
shone190
Poruka: 438
Poruka od shone190 » četvrtak, 19. jun 2014. u 22:43h
Iskreno, nemam pojma koliko KS/Nm ima ovaj motor. Otici cu sledeceg meseca na merenje pa cu sa sigurnoscu znati, ali ne verujem da je to neka velika snaga za danasnje pojmove, no videcemo :)
Poruka: 16358
Poruka od Talladega_500 » petak, 20. jun 2014. u 14:27h
Jel to takodje Moparov motor ili neki custom uradjen?
shone190
Poruka: 438
Poruka od shone190 » petak, 20. jun 2014. u 16:38h
Chrysler 440 blok u osnovi.
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » subota, 21. jun 2014. u 23:52h
A gde ces stari motor da bacis.... mrgreen
SlikaSlikaSlikaSlika
Poruka: 7731
Poruka od dax92 » nedelja, 22. jun 2014. u 10:30h
800 Nm lol
Sone, koji si ti car!! :clap:
zeteks
Poruka: 1298
Poruka od zeteks » nedelja, 22. jun 2014. u 21:33h
Cek prvo da resi to sto mu curi ulje iz menjaca.
shone190
Poruka: 438
Poruka od shone190 » nedelja, 22. jun 2014. u 22:20h
Taj semering na biracu brzina cu da zamenim kada budem ubacivao ceo motor, posto i tako sve ide napolje.
shone190
Poruka: 438
Poruka od shone190 » utorak, 15. jul 2014. u 16:33h
Lagano se krece sa restauracijom, duze vremena ga nece biti na ulicama :)
shone190
Poruka: 438
Poruka od shone190 » utorak, 15. jul 2014. u 21:11h
SlikaSlika
cdusan
Poruka: 508
Lokacija: Loznica
Poruka od cdusan » sreda, 16. jul 2014. u 16:13h
Kad ga zavrsis ima Charger da se propinje thumbsuph
shone190
Poruka: 438
Poruka od shone190 » četvrtak, 17. jul 2014. u 20:41h
Al' ima da se otelim do tada :) :) :)
SlikaSlikaSlikaSlikaSlika
Stigli i osiguraci :)
shone190
Poruka: 438
Poruka od shone190 » subota, 19. jul 2014. u 18:05h
Fabricki zvucnik posle 41 godinu stajanja u tabli :)
Poruka od BojanM » subota, 19. jul 2014. u 19:01h
Ne znam kako se tebi čini, ali ovo za moj pojam uopšte nije u lošem stanju, kad se uzmu u obzir 4 decenije otkako je napustio fabriku (i ne, ne pričam samo o zvučniku). ;)
shone190
Poruka: 438
Poruka od shone190 » subota, 19. jul 2014. u 19:10h
Deluje stvarno da je u veoma dobrom stanju za 41 godinu :) Mislim da ne bi trebalo da bude nekih vecih vratolomija oko radova na limariji.
Poruka: 6106
Poruka od Daniel » subota, 19. jul 2014. u 19:11h
Pato je super vest!
bossko77
Poruka: 1378
Lokacija: MYH3E
Poruka od bossko77 » subota, 19. jul 2014. u 20:22h
Kako bih ja ovako nesto sredjivao...srecno sa radovima .. thumbsuph
shone190
Poruka: 438
Poruka od shone190 » nedelja, 20. jul 2014. u 12:40h
Charger napokon odslepan, ostaje jos da se izvade motor i menjac, izduv, rezervoar i jos nesto sitnica, pa krecu visemesecni radovi na limariji :)
Poruka: 6106
Poruka od Daniel » ponedeljak, 21. jul 2014. u 08:15h
cool
kazi majstoru sa slike da pogresan auto gituje :D hahahahah :D
shone190
Poruka: 438
Poruka od shone190 » petak, 25. jul 2014. u 19:34h
SlikaSlika
zeteks
Poruka: 1298
Poruka od zeteks » subota, 26. jul 2014. u 22:29h
Peskarenje?
