Testiranje zivaca
novi81
Poruka: 661
Re: Testiranje zivaca
Poruka od novi81 » nedelja, 29. mar. 2015. u 21:24h
Evo ja sam ovako radio :
Mk3
The procedure for the Mk3 is slightly different, according to the Haynes manual. They recommend doing the following once the PCM (or ECU) has been disconnected for a while:
To allow the PCM to relearn, start the engine and run it as close to idle speed as possible until it reaches its normal operating temperature Then run it for approximately two minutes at 1200rpm Next, drive the vehicle as far as necessary - approximately 5 miles of varied driving conditions is usually sufficient to complete the relearning process.
Dalmatinac
Poruka: 1257
Lokacija: Subotica
Poruka od Dalmatinac » nedelja, 29. mar. 2015. u 23:05h
mbole piše:U nekom od prethodnih postova si napisao da je jedna dizna remontovana.
Da li je ta dizna posle toga isla na test sto da joj se odredi novi kod, i da li je taj novi kod unet u racunar automobila?
Kad resetujes comp, dizne startuju da tako kazem "od nule", to jest bez prilagodjavanja koja sam racunar automobila pravi vremenom.
Takodje, postoji procedura kako treba nakon toga da radi auto. Bese nesto prvo na leru neko vreme, pa na nekim obrtajima neko vreme, pa onda voznja kroz razlicite rezime...
Ubacen je novi kod u racunar automobila
Programming
Poruka: 8419
Poruka od FM III » ponedeljak, 30. mar. 2015. u 01:07h
Stvarno miriše, alal ti nos Staniću.
Dalmatinac
Poruka: 1257
Lokacija: Subotica
Poruka od Dalmatinac » ponedeljak, 30. mar. 2015. u 01:23h
Nisi interesantan :P
Programming
