- Poruka: 8421
Godine nisu bitne.
- Poruka: 15677
Samo 1993-1994 se proizvodio, samo 126 sedana su ikada proizvedena (i jos mali broj coupea i karavana). 5.0L V8 sa 375 ks, 0-100 km/h za 4.2 sekunde, maksimalna brzina 280 km/h.vidovac piše:Ovo neka ogranicena serija bila ili?
Nov je kostao $65,000 ovde u USA, sto izadje $109,000 danasnjih.
- Poruka: 15199
Dugmici najvise lice na podesvanje i memoriju sedista
To 4.2s do 100 nema sanse s tim menjacem..
- popovicvl
- Poruka: 5690
Zašto misliš tako. To je verovatno menjač sa 4 brzine, 1 ide do 100ke
- Poruka: 13655
Dekishaaaa
- Poruka: 850
- Član foruma od: subota, 6. jun 2015. u 17:43h
- Lokacija: Jagodina
Jel ima trenutno u usa v6 dizeli u ponudi ili neki drugi dizelasi?
- Poruka: 15677
Ima i I4 i V6 i V8 dizela.
Dekishaaaa
- Poruka: 850
V8 zvuci zanimljivo sto imate u ponudi?
- popovicvl
- Poruka: 5690
Lion V8
Built at Ford’s Dagenham engine plant in Essex, the 3.6-litre V8 twin-turbo diesel engine began production in April 2006.
Much speculation in the United States has focused on this engine as a possible Diesel entrant in the F-150 pickup truck and Expedition SUV.[2] It was announced that the new F150 engine will be based on this engine and enlarged to 4.4L. The Cleveland Engine plant recently began small-scale production of the exotic compacted graphite iron (CGI) used in the block's construction, leading many to expect production of the engine there.
3.6 TDV8
Engine configuration & engine displacement
90-degree V8 engine, twin-turbo diesel, 3,630 cc (222 cu in), bore x stroke 81.0 mm × 88.0 mm (3.19 in × 3.46 in), compression ratio 17.3:1
Cylinder block & crankcase
Compacted graphite iron cross bolted block
Cylinder heads & valvetrain
High strength aluminium, DOHC with 4 valves per cylinder
Aspiration
Twin-turbochargers with air-to-air intercooler, electronically actuated variable geometry with transient over-boost capability, port deactivation system
Fuel system & engine management
Siemens Common rail (CR) direct diesel injection, maximum injection pressure of 1,650 bars (23,900 psi), piezo injectors
DIN-rated motive power & torque outputs
200 kW (270 hp), 640 N·m (470 lbf·ft) – Range Rover, Range Rover Sport
3.6 TDV8
Aspiration
- Poruka: 21769
Ono kao powerstroke v8 i tako to...
- Poruka: 15199
Taj lion v8 bi trebalo da je evolucija v6 2.7 koji je isao u range, pug coupe i cini mi se neki jag
- Poruka: 15677
Ford ima 6.7L V8 poznat kao PowerStroke. 440 ks i 1,166 Nm obrtnog momenta.Dekishaaaa piše:V8 zvuci zanimljivo sto imate u ponudi?
General Motors ima 6.6L V8 poznat kao Duramax, uradjen u saradnji sa Isuzu.
Sad je i Nissan Titan dobio 5.0L V8 dizel koji proizvodi Cummins.
- Poruka: 15677
Ta vest je stara dobrih 10-ak godina, ako ne i vise. Ford je odavno potvrdio da F-150 dobija 3.0L V6 dizel za 2018. godinu.popovicvl piše:Lion V8
Dekishaaaa
- Poruka: 850
Nenadmasni motori sa tolikim obrtnim momentom,odmah ga zamisljam na nekom rancu tipa 1.000 hektara sto mu i pristoji jel te?
A neka limuzina kao fusion i tako to nemaju u ponudi dizelase?
- popovicvl
- Poruka: 5690
Znam. Meni je zao što Ford kad je već eksperimentisao sa poslednjom generacijom Mustanga, nije eksperimentisao do kraja sa nekim diesel V8Talladega_500 piše:Ta vest je stara dobrih 10-ak godina, ako ne i vise. Ford je odavno potvrdio da F-150 dobija 3.0L V6 dizel za 2018. godinu.
- Poruka: 15677
Cemu to u Mustangu?
- Poruka: 15677
Kako kad, jer ih ljudi koriste i da vuku prikolice u gradovima. Moj prvi komsija dok sam ziveo kod kuce je radio na gradjevini, svako jutro je vukao ogromnu prikolicu sa materijalima, a za vucu je koristio Ford F-350 dizel.Dekishaaaa piše:Nenadmasni motori sa tolikim obrtnim momentom,odmah ga zamisljam na nekom rancu tipa 1.000 hektara sto mu i pristoji jel te?
Ne. Jedini koji je imao u radnickoj klasi je bio Volkswagen u Passatu sve do Dieselgate. Prica se da bi Mazda mogla imati u narednih nekoliko godina.Dekishaaaa piše:A neka limuzina kao fusion i tako to nemaju u ponudi dizelase?
Mislim da jos uvek Mercedes nudi dizel u E-Class.
- popovicvl
- Poruka: 5690
Da bi mogao otici ponekad na neki dalji put i biti najbrzi.
Dekishaaaa
- Poruka: 850
Super vesti @Talladega_500
Pratim ovu page od sad,bilo bi lepo neki diesel test za nas eu east
- Poruka: 15677
Moj '00 Mustang je obisao celu Ameriku.popovicvl piše:Da bi mogao otici ponekad na neki dalji put i biti najbrzi.
- Poruka: 15677
Tesko da ce biti prilike. Jos me nikad nije zapao dizel.Dekishaaaa piše:Super vesti @Talladega_500
Slaba vajda od rašrafljenih ogromnih dizela za široke narodne mase sa rigoroznim zakonima o emisiji u USA.
Ma tamo gorivo njima dzabe a dizel nema na svakoj pumpi i skuplji je..sto se ne siriti kad vec mogu
Dekishaaaa
- Poruka: 850
pa ta E classa sig ispunjava te norme rigorozne cim se prodaje tamo,i voleo vih da je vidim..
