FIesta 1.4 TDCI cudan zvuk ili ?
- Poruka: 15299
Re: FIesta 1.4 TDCI cudan zvuk ili ?
Bas tako.
Grejaci rade i kada je motor vec upaljen (pise gore kad i koliko)
Dizel nema svecicu, vec pali tako sto se pri sabijanju podizu pritisak i temperatura u cilindru na oko 700 - 900 stepeni, pa se smesa pali sama od sebe. Kada je motoru hladno (a to je i na +40, njemu je normalana temperatura 100), ne moze da se upali smesa, ili se barem pali daleko teze nego kada je kompresioni prostor ugrejan.
Danasnji grejaci postizu neke sulude temperature za uzasno kratko vreme (tipa 1000 stepeni za manje od dve sekunde).
- xXStrahinjaXx
- Poruka: 971
- Član foruma od: utorak, 1. mar. 2016. u 15:09h
Zajebavas ?
Ford Fiesta 1982 960cc
Ford Fiesta 1.25 2004
Ford Fiesta 1.4 TDCI 2007
Ford Fiesta 1.4 TDCI 2008
Ford Kuga 1.5 EB 2015
Kia XCeed 2020
Kia XCeed 2020
- Poruka: 15299
Ako laze NGK, lazem i ja:
The ceramic high-temperature glow plug (“NHTC glow plug”, “New High Temperature Ceramic”) has a fully ceramic heating element. The NHTC ceramic glow plug was specially developed by NGK to enable automotive manufacturers to comply with ever-stricter emissions standards. One of the goals of these standards is to reduce the compression ratio in diesel engines. NHTC glow plugs reach a temperature of 1,000°C in less than two seconds and can after-glow for more than ten minutes at temperatures of up to 1,350°C.
https://www.ngkntk.com/uk/products/glow-plugs/
Uostalom.... celik dobija jarko crvenu boju negde na oko 800 stepeni. A vrh grejaca se usija otprilike tako za cas.
- Daki_81
- Poruka: 2611
@Strahinja Samo na jačem minusu (oko - 6/7°C) ćeš videti malo duže lampicu grejača, tipa 3-4 sekunde
- xXStrahinjaXx
- Poruka: 971
E pa zato....pre par dana kad je bio sneg i onaj minus sam vidjao spiralicu kako svetli,sinoc nisam.....zato sam se i uplasio ...rekoh nije valjda to riknulo.
Kia XCeed 2020
Kia XCeed 2020
- Daki_81
- Poruka: 2611
Opušteno i bolje da je ne vidiš, pogotovo u vožnji
- xXStrahinjaXx
- Poruka: 971
A sta znaci ako se vidi u voznji?
Kia XCeed 2020
Kia XCeed 2020
- Poruka: 6712
Znaci sjebo (o)(o). Obicno govori da je problem sa ubrizgavanjem, tj da je nesto crklo ili pumpa ili dizne
- Daki_81
- Poruka: 2611
E to...
- Poruka: 15299
Uglavnom znaci da treba da pocnes da se oprastas sa novcanikom
- milosjov
- Poruka: 177
- Član foruma od: nedelja, 30. okt. 2016. u 11:11h
Tek sad sam video ovu temu i pregledao snimak. Na moju veliku žalost poklapa se sa zvukom koji u poslednje vreme sve češće čujem. Veliki servis je rađen prošle godine u RSD-u tako da ne verujem da je neki kaiš ili slično. Videviši ove poslednje komentare skupljam hrabrost do odem u servis ponovo
Послато са Mi A1 уз помоћ Тапатока
- Poruka: 15299
Poslednji komentari se odnose na paljenje lampice grejaca, a ne na cudan zvuk.
Procitaj sve postove, a ne samo prvi i zadnji
To sto je servis radjen prosle godine, ne mora da znaci da neki deo nije propao. Garancija sluzi upravo zato sto niko na svetu ne moze da uvek napravi savrseno ispravan deo.
Kod kvarova nema "verovanja". Pregleda se i ustanovi sta je. Sve ostalo je zavaravanje samog sebe.
- xXStrahinjaXx
- Poruka: 971
Uradio mali servis(Jos ne veliki) taj zvuk je osetno manji.Ali je i dalje prisutan.
Kia XCeed 2020
Kia XCeed 2020
- xXStrahinjaXx
- Poruka: 971
Resen problem KAIS NA ALTERNATORU SE CUO!!!
Kia XCeed 2020
Kia XCeed 2020
