Staklo nije ni minimalno zakrivljeno, a sto se tice funkcije grejaca.. to tesko da cu sad proveriti jer je napolju 30C
Ford VIN i spisak opreme
Almighty.shO
- Poruka: 1787
Re: Ford VIN i spisak opreme
Evo ovako, moje zapazanje
- Poruka: 7741
oseti se, jos kako
Ako radi, naravno
- Poruka: 15284
De slikaj taj retrovizor
- dejanmar
- Poruka: 78
- Član foruma od: sreda, 29. okt. 2008. u 10:32h
- Lokacija: Mladenovac
Zdravo, trebalo bi kad skunes zadnji poklopac da vudus da li je neki kabl prikacen za staklo. (Tako je bilo bar kod mene na focus-u mk1 gde sam imao grejace u retrovizoru).
Sent from my Tesla_SP9 using Tapatalk
Almighty.shO
- Poruka: 1787
Almighty.shO
- Poruka: 1787
- Poruka: 8421
Može li neko ovaj broj da pogleda opremu i šta još može iz VIN-a? Broj: WF05XXWPD57D74244
Meni na etis.ford.com izbaci samo koji je motor i model, ništa više.
Almighty.shO
- Poruka: 1787
Udji u Ford Etis, i kad proveris taj VIN klikni na ta dva plusa i imas sve
Ukoliko i dalje nece, evo ti ovde:
Primary Features
Build Date: 26.03.2007
Vehicle Line: Focus 04-08/Focus C-MAX 03-07
Body Style: 5 Door Saloon
Version: Series 15
Engine: 1.6L Duratorq TDCi (90PS) - DV6
Transmission: 5-Speed Manual Trans - MTX75
Drive: LHD FWD
Emission: Stage IV Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"I"
Paint: Panther Black (Metallic)
Interior Fabric: Rack / Dark Flint (B-C)
Minor Features
Valencia Plant Built
Security Lock Group No.1
With Convenience Group
Marketing Flex Prep Pack 3
Less SVO Application/Label
Marketing Level 1
Less Electronic Stability Control
Less Tyre Repair Service Kit
Power Front Windows One Touch Down
With Manual Rear Windows
With Tinted Glass All Round
Less Windshield Heat Shielding
Less Heated Windscreen
Less Temp Controlled Glove Box
Less Overhead Console
With Short Floor Console
With Velour Front Floor Mats
With Velour Rear Floor Mats
With Conventional Headlining
Sunvisor-Driver Vinyl W/Mirr Insert
Sunvisor-Pass Vinyl W/Mirr Insert
Less Cargo Stowage Rack/Rail
Less Driver Roof Storage
Less Roof Rack
With Rear Spoiler
With Dipping Rear View Mirror
Drivers Power Heated Convex Mirror
With Pass Convex Elec/Heated Mirror
With Split Fold-Down Rear Seat
With Rear Center Head Restraint
Less Driver Seat Lumbar Support
Less Temp Control Driver Seat
Less 2nd Row Rear Seat
With Driver 4 Way Mnl.Seat Adjuster
With Pass 2 Way Manual Seat Adjust
Ignition Key With Remote Unit
With Moulded Gearshift Knob
With Central Locking System
With Door Entry Remote Control Unit
With Variable Intermittent Windscreen Wiper
Less Sun Roof
Air Curtain Restraint LH
Air Curtain Restraint RH
With Driver Air Bag
With Passenger Air Bag
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
Spare Wheel - Mini Steel
With Standard Rear Shock Absorbers
6.5 X 16 Alloy Wheel
205/55VR-16 BSW Tyre
Less Wheel Covers
Non Locking Lug Nuts
With Handling Suspension
With Mechanical Parking Brake
Less Brake Emergency Assist
4 Wheel Anti-Lock Braking System
Less Skid Plates
Sports Front Seat
With Fixed Foot Pedals
Steering Wheel - 3 Spoke Leather
Less Auxiliary Heater
Less Radio Pre-Equipment Pack
(+)RDS
With A/V Jack
With Centre Antenna
High Level With CD And AM/FM Radio
Ice Feature Pack 6
With 8 High Series Radio Speakers
With Column Stalk Radio Controls
With Smokers Pack Type 2
With Halogen Headlamp
Less Daytime Running Lamps
With Front Fog Lamps
Less Cornering Lamp
With Header Courtesy Light
Less Rear Overhead Reading Lamps
Less Headlamp Control
Primary Features
Version: Series 15
Drive: LHD FWD
Territory: (+)"I"
Minor Features
Marketing Level 1
Less Roof Rack
With Rear Spoiler
Less Sun Roof
With Driver Air Bag
Less Wheel Covers
Less Skid Plates
Sports Front Seat
(+)RDS
With A/V Jack
With Centre Antenna
Ice Feature Pack 6
Less Cornering Lamp
- Daki_81
- Poruka: 2611
I kod mene nema tih dodatnih informacija sa ta dva plusa
Nekad mi je sve podatke davao na Etisu...
- Poruka: 8421
Hvala.
Nemam te pluseve. Vidio bi ih da su tu.
- boki_8888
- Poruka: 23
- Član foruma od: nedelja, 21. apr. 2019. u 09:12h
Mogli bi ste, u duhu parlamentarne demokratije, da stavite jedan univerzalni nalog za etis.ford.com i catcar.info koji bi koristili svi članovi foruma. Tako su bar radili ljudi sa citroen foruma. Pozz.
- Djole
- Master of Tanjirača
- Poruka: 4987
- Lokacija: Valjevo
Za catcar ne treba nalog moze svako da vidi. Bar je tako bilo pre par dana
Almighty.shO
- Poruka: 1787
- boki_8888
- Poruka: 23
Very thanks
- dzajko75
- Poruka: 188
- Član foruma od: nedelja, 5. jan. 2014. u 21:07h
- Lokacija: Jagodina
Hvala drug za ovo.
A sta li mu znaci ovo:Territory:(+)"A"?
Gde je direktorka?
Direktorka je na rucku trenutno.
Kad sidje sa tu rucku neka mi se javi...
- Poruka: 21914
proizveden za tržište austrije
- dzajko75
- Poruka: 188
Aha to li je.Pa ja sam ga i uvezo iz AT:
Gde je direktorka?
Mihonja
- Poruka: 39
- Član foruma od: subota, 6. apr. 2019. u 12:43h
WF03XXGCDX35M77514... Sta god pokusavao, ne izbacuje mi podatke na etisu sem motora, boje... Ako nije problem, zamolio bih nekoga da pogleda i posalje... Hvala unapred
WF03XXGCD35M77514... ispravka
- sarabo
- Poruka: 2276
pokušao san na catcar, ali prijavljuje grešku, jesi li dobro uneo broj šasije ?
mislim da imaš jednu oznaku viška, treba da ih je 17
Poslednja izmena: sarabo, na dan sreda, 24. jul 2019. u 13:23h. Ukupno izmenjeno 1 put.
Fiesta 1.8 d ( 1997 )
Mihonja
- Poruka: 39
WF03XXGCD35M77514
Imam
Imam
- sarabo
- Poruka: 2276
Drivers Air Bag With Driver Air Bag
Passengers Air Bag With Passenger Air Bag
Front Fog Lamp Type With Front Fog Lamps
Drivers Seat Adjustment Type With Driver 4 Way Mnl.Seat Adjuster
Ignition Key Type Ignition Key With Remote Unit
Tinted Glass With Tinted Glass All Round
Radio Information Decoder (+)RDS
Speedometer Types With KMH Speedometer
Marketing Levels Marketing Level 1
Passenger Seat Adjustment Type With Pass 2 Way Manual Seat Adjust
Side Air Bag - Drivers Side With Side Air Bag - Drivers Side
Side Air Bag - Passenger Side With Side Air Bag - Passenger Side
Rear View Mirror Type With Dipping Rear View Mirror
Radio Antenna Type With Centre Antenna
Wheel Size & Style 16 Inch 6.5 X 16 Trend Alloy Wheel
Headlamps - Design With Halogen Headlamp
Marketing Flex Prep Pack Marketing Flex Prep Pack 10
Rear Shock Absorber Type With Standard Rear Shock Absorbers
Air Curtain Restraint(RH/LH) Air Curtain Restrnt LH
Dynamic Stability Control With Electronic Stability Control
Air Curtains (Use CP1 Family) Air Curtain Restrnt RH
Parking Brake - Function Type With Mechanical Parking Brake
Radio Controls - Column Stalk With Column Stalk Radio Controls
Adjustable Foot Pedals With Fixed Foot Pedals
Windscreen Wash/Wipe With Variable Intermittent Windscreen Wiper
Spare Wheel Type Spare Wheel - Mini Steel
A/V Jack With A/V Jack
Security Lock Group Security Lock Group #5
Door Locking Systems With Door Dead Locks
Rear Brake Type With Rear Disc Brakes
Plant Build Requirements Saarlouis Plant Built
Instrumentation Type Conventional Instruments - Level 2
Front Floor Mat Style Front Floor Carpet Mats
Smokers Package With Smokers Pack Type 2
Rear Window Operation With Fixed Rear Side Window
Auto Headlamps With Auto Headlamps
In Car Entertainment High Level With CD And AM/FM Radio
Passenger Door Mirror Type With Pass Convex Elec/Heated Mirror
Brake Emergency Assist With Brake Emergency Assist
Header Mounted Map Reading Lamps Header Mounted Courtesy/Maplights
ICE Feature Pack Ice Feature Pack 6
Front Window Operation Power Front Windows One Touch Down
Front Seat Type Sports Front Seat
Gearshift Knob With Moulded Gearshift Knob
Convenience Group With Convenience Group
Alarm Systems Perimeter / Volume Theft System
Driver Door Mirror Type Drivers Power Heated Convex Mirror
Overhead Console With Mini Overhead Console
Centre Console With Short Floor Console
16 Inch Tyres 205/55VR-16 BSW Tyre
Suspension Types With Handling Suspension
Radio Speakers With 8 High Series Radio Speakers
Mihonja
- Poruka: 39
- sarabo
- Poruka: 2276
ima li još neko problem sa catcar da kad se klikne na info za kola da mu otvori sa leve strane jedva vidljivo na ekranu i ne mogu ga pomeriti nigde na drugi deo ekrana
Almighty.shO
- Poruka: 1787
https://www.etis.ford.com/home/loginForm.do
Username: shO
Password: shO12345678900
Updejtovana sifra.
Username: shO
Updejtovana sifra.
- Poruka: 10010
Zahvaljujem
