Mondeo mk3 nece da zavergla?
Poruka: 15038
Re: Mondeo mk3 nece da zavergla?
Poruka od mbole » utorak, 21. nov. 2023. u 10:54h
Imas problem sa imobilajzerom.
Koji konkretno.. dijagnostika.
Ili... sacekaj da prestane da brzo trepce i posle toga ce preci na treptanje koje oznacava kod greske
Imas u Surcinu Vukasinovice.
Kôd: Označi sav tekst
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³  Indicator   ³           Description/Condition            ³     Possible Source      ³       Action       ³
³  Flash Code  ³                                            ³                          ³                    ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³      11      ³  PATS transceiver signal is not received   ³   Transceiver wiring     ³  GO to Pinpoint    ³
³              ³                                            ³ transceiver connector,   ³      Test A.       ³
³              ³                                            ³    transceiver or PCM    ³                    ³
³      12      ³ Transceiver antenna coil concern, Vehicle  ³       Transceiver        ³   Install a new    ³
³              ³               does not start               ³                          ³    transceiver     ³
³      13      ³ Non-PATS key or damaged encoded ignition   ³  PATS encoded ignition   ³ REFER to WDS PATS  ³
³              ³ key, or no key code received. Vehicle does ³           key            ³ test. Follow the   ³
³              ³                 not start                  ³                          ³    instructions    ³
³      13      ³  Transponder programming concern, Crypto   ³       Ignition key       ³ REFER to WDS PATS  ³
³              ³  transponder only. Vehicle does not start  ³                          ³ test. Follow the   ³
³              ³                                            ³                          ³    instructions    ³
³      14      ³ Partial key read of PATS key. Vehicle does ³  PATS encoded ignition   ³ REFER to WDS PATS  ³
³              ³                 not start                  ³     key. Transceiver     ³ test. Follow the   ³
³      15      ³ Incorrect key code, Unprogrammed PATS key  ³  PATS encoded ignition   ³ REFER to WDS PATS  ³
³              ³   (keycode format OK). Vehicle does not    ³           key            ³ test. Follow the   ³
³              ³    start (20 second anti-scan invoked)     ³                          ³    instructions    ³
³      16      ³ CAN communication link between the PCM and ³ Circuit, Fuel injection  ³ REFER to WDS PATS  ³
³              ³ Fuel injection pump control module (diesel ³ pump control module or   ³ test. Follow the   ³
³              ³       only). Vehicle does not start        ³           PCM            ³    instructions    ³
³      21      ³  Number of programmed PATS encoded keys    ³ Incorrect number of keys ³ REFER to WDS PATS  ³
³              ³   below minimum. Vehicle does not start    ³   programmed or PATS     ³ test. Follow the   ³
³              ³                                            ³   encoded ignition key   ³    instructions    ³
³      22      ³ NVM Configuration failure. No security ID  ³   New PCM or new fuel    ³ REFER to WDS PATS  ³
³              ³  exchange between PCM and Fuel injection   ³ injection pump control   ³ test. Follow the   ³
³              ³ pump control module (diesel only). Vehicle ³          module          ³    instructions    ³
³              ³               does not start               ³                          ³                    ³
³      23      ³   Data mismatch (received data does not    ³   New PCM or new fuel    ³ REFER to WDS PATS  ³
³              ³ match what was expected) Security messages ³ injection pump control   ³ test. Follow the   ³
³              ³     do not match between PCM and Fuel      ³          module          ³    instructions    ³
³              ³  injection pump control module. Vehicle    ³                          ³                    ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
Povratak na „Instalacije“
