Koje ulje sipate u fordove?
Nije mesto za kvarove.
milosbgd
Poruka: 12
Član foruma od: ponedeljak, 11. maj 2009. u 21:58h
Poruka od milosbgd » nedelja, 16. avg. 2009. u 21:53h
U mog Escorta 1.8TD sipav Ford formula XR+ 10-40. Potrosi mi oko 600 grama ulja izmedju promena (menjam na 5000-6000 km).
peca
Poruka: 2469
Lokacija: Beograd - Mirijevo
Poruka od peca » petak, 21. avg. 2009. u 19:55h
Poruka: 21954
Poruka od Markedjani » petak, 21. avg. 2009. u 23:05h
Opa bato... nisam video taj Motul...
Jel to ima da se uzme kod nas ili si to već sipao u Escorta ? :)
mondeo-koki
Poruka: 2
Član foruma od: petak, 24. jul 2009. u 09:44h
Poruka od mondeo-koki » nedelja, 23. avg. 2009. u 21:48h
Koje ulje ja da sipam u ford mondeo 2001 1.8 b dura tec 125ks? Po specifikaciji je 5w40...
Dragomir
Oficijalni serviser
Oficijalni serviser
Poruka: 5507
Lokacija: Avala-BG
Poruka od Dragomir » nedelja, 23. avg. 2009. u 21:49h
5w30 formula E ili F FORD
fancy
Poruka: 2265
Lokacija: 11090
Poruka od fancy » ponedeljak, 24. avg. 2009. u 04:01h
Specifikacija za taj Mondeo kaže sledeće, direktno iz manuala, bold originalan:
Engine oil change Use Ford/Motorcraft Formula E SAE 5W-30 engine oil. Alternative engine oils with the viscosity SAE 5W-30 meeting the requirements of Ford Specification WSS-M2C913-B may also be used.
Engine oil top-up If you are unable to find an oil that meets any of these specifications, you must use an oil of the viscosity SAE 5W-30, SAE 10W-40 or SAE 5W-40, according to outside temperatures, meeting the requirements of either ACEA A1/B1 or ACEA A3/B3 specifications. Use of these oils may result in longer cranking periods, reduced engine performance, reduced fuel economy, and increased emission levels.
g-bear
Poruka: 16
Član foruma od: petak, 21. avg. 2009. u 19:07h
Lokacija: Prokuplje
Poruka od g-bear » ponedeljak, 24. avg. 2009. u 19:37h
Ja sam u Fiestu sipao Mobil sinteticko, i promenio filter za gorivo, a to radim na 15 000 km.
Dragomir
Oficijalni serviser
Oficijalni serviser
Poruka: 5507
Lokacija: Avala-BG
Poruka od Dragomir » ponedeljak, 24. avg. 2009. u 20:47h
Nema potrebe za tako skupim uljem ;)
peca
Poruka: 2469
Poruka od peca » ponedeljak, 24. avg. 2009. u 23:33h
Markedjani piše:Opa bato... nisam video taj Motul...
Ima u Mass company u Jovanke Radakovic...
Cena je oko 1500 dinara za 1l, ali i te kako vredi svake pare 8) ...
Sipao sam u Escorta i mogu ti reci da sam prezadovoljan ;) ...
Dragomir
Oficijalni serviser
Oficijalni serviser
Poruka: 5507
Lokacija: Avala-BG
Poruka od Dragomir » ponedeljak, 24. avg. 2009. u 23:36h
Mislim da je to previse para posto litar Formule F kojega proizvodi Castrol kosta 600
peca
Poruka: 2469
Poruka od peca » ponedeljak, 24. avg. 2009. u 23:42h
Znam da je papreno, al kad jednom sipash ovo ulje videcesh da vredi svakog ulozenog dinara ;) ...
Poruka: 5143
Poruka od Neša » ponedeljak, 24. avg. 2009. u 23:50h
Mislim da je to bacanje para. U escort mk6 1.3 stavi Ford 10/40 polusintetiku ili ako ti bas merak 5/30 koje nije vise od 600din,milina ;)
Dragomir
Oficijalni serviser
Oficijalni serviser
Poruka: 5507
Lokacija: Avala-BG
Poruka od Dragomir » ponedeljak, 24. avg. 2009. u 23:52h
Vidis ja trosim negde oko 4000-5000 litara ulja godisnje i nemam nikakvih problema sa potrosnjom ulja kod musterija i na vozilima koje vozimo(ne stedimo ih).Dok cim musterija sipa neko imalo gusce ulje pocinje da trosi.Sipao sam ga drugaru koji ima audi A3 benzinac posto mu je trosio Mobil 0w30 i neki Castrol jedno 1L na 1000 km a sada Formulu tropsi 1L na 9000 km.Da nepricam o jos hiljada vozila koji su imali probleme sa Seleniom i bog zna kojima uljima.Naj bitnije je da se zna poreklo ulja posto Indjija i gradovi oko nje rade cuda
peca
Poruka: 2469
Poruka od peca » utorak, 25. avg. 2009. u 00:12h
neskopk piše:Mislim da je to bacanje para. U escort mk6 1.3 stavi Ford 10/40 polusintetiku ili ako ti bas merak 5/30 koje nije vise od 600din,milina ;)
Milina ili ne, na ulju ne treba shtedeti ;) ...
Mislim da je bolje dati 1000+ din. za stvarno kvalitetno ulje, nego sipati bilo shta, pa da posle bude joj :S ...
Poruka: 21954
Poruka od Markedjani » utorak, 25. avg. 2009. u 00:57h
Uff 1500 dinara... da je soma dingera sipao bih taj Motul,pošto hoću sledeću zamenu da sipam sintetiku u Sierru.
Oduvek sam sipao Motul u svaki auto koji ostane duže vreme kod mene i nikad nisam imao problema...
Ali što je mnogo puno je :|
BokiRS
Neizleciv
Neizleciv
Poruka: 4459
Poruka od BokiRS » utorak, 25. avg. 2009. u 08:32h
Ja sam sipao sve i svasta u moj auto i kao sto mnogi znaju nisam stedeo kao sto nikada i ne stedim kad je moj auto u pitanju.
Uvek sam imao neku malu potrosnju ulja dok nisam kod Dragomira poceo da sipam Ford formulu 5w30.
Chip tuning za Ford-ove
viewtopic.php?f=94&t=19067
Poruka: 5143
Poruka od Neša » utorak, 25. avg. 2009. u 09:43h
Kazem milina zato sto mozemo da budemo sigurni da je ulje originalno,a uz to je izuzetno kvalitetno pa jos i kosta malo,to ima samo kod Forda ;)
Culi ste sta kaze Dragomir,cuda se desavaju sa tim poznatim uljima...
fancy
Poruka: 2265
Lokacija: 11090
Poruka od fancy » utorak, 25. avg. 2009. u 09:53h
peca piše:Cena je oko 1500 dinara za 1l, ali i te kako vredi svake pare 8) ...
Sipaj Ford Formulu F i za razliku u parama vodi ekipu negde na klopu tako će bar 5-6 ljudi biti prezadovoljno. O Escortu da i ne govorim :D
peca
Poruka: 2469
Poruka od peca » sreda, 26. avg. 2009. u 02:22h
Moja greshka, cena je 1100 din, sad sam gledao cenovnik...
magick
Poruka: 55
Član foruma od: petak, 21. avg. 2009. u 12:44h
Poruka od magick » četvrtak, 27. avg. 2009. u 11:08h
BokiRS piše:Uvek sam imao neku malu potrosnju ulja dok nisam kod Dragomira poceo da sipam Ford formulu 5w30.
Pa sta sad to znaci... ti cenis da je to ulje bezveze? Mislim... iskomplikovaste ga...
Moj cale je sipao oduvek samo Castrol polu-sinteticko i menjao ga na nekih 9000km. Auto nikada nije trosio ulje, barem ne primetno...
Poruka: 5143
Poruka od Neša » četvrtak, 27. avg. 2009. u 11:36h
Jao bre... :)
Sve je jasno ko dan,za Forda Fordovo ulje i ne komplikujes nista
magick
Poruka: 55
Poruka od magick » četvrtak, 27. avg. 2009. u 11:43h
Hahahahaha!!! lol Jaooj!
Ja ga razumeo da je uvek imao neku MALU potrosnju, dok nije poceo da sipa Fordovo ulje... A onda... :D :D :D
Nista... Odo' ja kod Dragomira... ;)
peca
Poruka: 2469
Poruka od peca » četvrtak, 27. avg. 2009. u 13:56h
Xexexe, ko je ovde lud, a ko zbunjen??? lol lol lol
microslav
Poruka: 59
Član foruma od: utorak, 25. avg. 2009. u 12:42h
Lokacija: Požarevac, Srbija
Poruka od microslav » petak, 28. avg. 2009. u 19:07h
odlicna diskusija,
iz svega navedenog ovde, a i po raznoraznim uputstvima ja sam izvukao zakljucak da su svi Fordovi malo probirljiviji kad su motorna ulja u pitanju i da bi trtebalo koristiti iskljucivo ulja sa Fordovom oznakom (ili specifikacijom) i to uglavnom 5W30 i eventualno 10W40.
"Standardno" ulje 15W40 bi koliko sam aj razumeo trebalo zaboraviti. Ok, nije to neki problem, spreman sam i voljan dati neki dinar vise za kvaliteno ulje, ali problem je gde u Pozarevcu naci takvo ulje. Ubio sam se od trazenja danas i nigde, ali bas nigde nisam nasao nikavo ulje sa Fordovom oznakom ili da bar pise da je po Fordovoj specifikaciji i svuda su me gledali kao da sam pao s marsa, a tek kad sam im trazio oznaku 5W30 palo je ubedjivanje da mi ne treba takvo ulje, da je retko, da ce se vise trositi odnosno isparavati itd i posle svega ovde recenog iskreno sumnjam u njihovo znanje.
elem, na samo 3 mesta sam nasao ulja 5W30 od toga na dva Castrol sa cenom 1400+ i 1500+ din i na jednom mestu AGIP Tecsint sa vrlo pristojnom cenom od 800 din. Kako sledeci citat kaze
fancy piše: Engine oil change Use Ford/Motorcraft Formula E SAE 5W-30 engine oil. Alternative engine oils with the viscosity SAE 5W-30 meeting the requirements of Ford Specification WSS-M2C913-B may also be used.
a u karakteristikama za AGIP Tecsint se kaze da zadovoljava specifikaciju ACEA A3/B3/B4, ja izvedoh zakljucak da mozda mogu koristiti to ulje, kad vec nikako ne mogu doci do originalnog, al rekoh da se najpre ovde konsultujem.
Inace da podsetim, imam Fiestu iz 1993 sa motorom od 1118ccm, cini mi se da taj motor pripada Kent familiji motora (nemojte se smejati, meni je ovo uopste prvi auto te mnoge stvari ne znam), kilometar sat pokazuje 61k kilometara (sto je mozda i moguce jer je Fiesta odlicno ocuvana, http://www.fordclubserbia.org/forum/vie ... f=6&t=1575 mada je verovatnija cifra od 161k km) i ne bih da je sjebem pogresnim izborom i ustedom od par stotina dinara.
evo linka na AGIP Tecsint http://www.motoworlduk.co.uk/products/m ... csint.html pa pogledajte specifikaciju i recite mi da li da uzmem to ulje.
Poruka: 5143
Poruka od Neša » petak, 28. avg. 2009. u 20:12h
Fordovo ulje ima samo u Fordovim radnjama. Ako nema bas nijedna u Pozarevcu onda neka ti neko posalje iz Beograda. Ali ja mislim da mozes da sipas neku polusintetiku 10w/40(bitno da je original) i da apsolutno nema potrebe da stavljas sinteticko ulje u motor stare konstrukcije
O ovom AGIP ulju neznam bas nista ;)
Mnogi se hvale ELF uljima,Motul je odlican,Selenija nije skupa,
