Racunari-servisi-saveti i uputstva
- Poruka: 15297
Re: Racunari-servisi-saveti i uputstva
Pogledaj kabl, jel ima svih 8 zica?
Cesto uz rutere dodje onaj sa 4
Sent using Tapatalk
Sent using Tapatalk
- Poruka: 2080
Kabl sam kupio i sam ga pravio. Ima 8 zica. Sumnjao sam da sam ga lose krimpovao pa sam utrosio 3-4 konektora po strani medjutim isto.
Ono sto mene buni jeste zasto pise da je konekcija od 1000 ako je los kabl/konektor, a opet zasto pise 1000 a ne moze da razvije 1000.
Sa mog problematicnog racunara:
Kôd: Označi sav tekst
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Half 1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
-> Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: d
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: yes
Drugi racunar koji nema gigabit
Settings for eth0:
1000baseT/Full
1000baseT/Full
-> Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Wake-on: d
Link detected: yesEDIT: Reseno... konektor zajebavao
- Poruka: 13676
Ako sam pravis, a nije oklopljen konektor, oce da zajebava za 1gbps. Takodje ako na samom konektoru ne uhvate oba bakarna pipka od kontakta vec samo jedan (ako ne gurnes duboko u konektor svaku zilu). Bar su to moja iskustva sa 100mbps vs 1gbps.
- skolioza
- Poruka: 1674
W10 pro odjednom vise nece da otvori podesavanja ili settings
Krekovan 64bitni
Samo otvori prozor i zatvori ga iste sekunde
Preko desnog klika na desktopu pa podesavanja pozadine izbaci ovu gresku
Takodje je prebacio sa engleskog na srpski a niko ga nije menjao.
Da li je neko imao slicna iskustva?
Krekovan 64bitni
- Poruka: 15297
Nema nikakvih problema da utp cat 5e kabl tera 1gbps
Krimpovanje kako treba je vec druga stvar
Prvo.. o kom kablu se radi?
Fly ili wall? Tj.. licnasti ili puni presek?
Wall kabl nije predvidjen za konektor vec za modul
Sent using Tapatalkdule0911 piše:Ako sam pravis, a nije oklopljen konektor, oce da zajebava za 1gbps. Takodje ako na samom konektoru ne uhvate oba bakarna pipka od kontakta vec samo jedan (ako ne gurnes duboko u konektor svaku zilu). Bar su to moja iskustva sa 100mbps vs 1gbps.
- Poruka: 2080
Pun presek, barem ovaj sto sam uzeo, tako da moguce da i to u kombinaciji sa jeftinim kljestima zajebava
- Poruka: 15297
Pun presek mora u modul, gde se ukljesti izmedju dva noza koji ga uvek drze pod kontaktom kao opruga.
"Vampiri" kakvi su na konektorima rade samo na licnastom kablu.
Sta god pricali trgovci i kako god krstili konektore.
Jednostavno vampir ne moze da se ubode u pun presek,ne znam kakva kljesta da imas.
I ako proradi u startu, to je problem u najavi, koji ce kad tad poceti da zaza na najgori moguci nacin.. cas radi cas ne radi cas losije radi...
Sent using Tapatalk
Sent using Tapatalk
- Poruka: 2080
Jbg, nisam znao a nit mi je prodavac spomenuo. Svakako mogu napraviti uticnicu negde sa ovim kablom i posle preci na licnasti. Tako da nije sve baceno. Hvala svima na savetima
Vec kad smo tu, preporuka za neki switch i ruter? Gledao sam neke asus modele, navodno mozes telefon da povezes sa njim preko USB-a pa da delis konekciju svim uredjajima.
@skolioza
Meni to lici na neki virus
@skolioza
- Poruka: 13676
Iz mog iskustva pun presek radi sa oklopljenim wall konektorima, nemam sad prazan pri ruci da fotkam. Imam kablove koje sam pravio, stare 10 godina, koji rade i dalje bez greske, a nisu staticni (ubodi i zaboravi varijanta). Zajebani su za rad jer je sve na knap, bakar se ne kaci za kontakte kao na obicnom konektoru vec sam kontakt ima vise pipaka koji ulaze kroz izolaciju oko bakra. Adekvatno je i skuplji od obicnog konektora.
- Poruka: 15297
Ne kapiram da li pricamo o istoj stvari.
Da li je kabl ili konektor STP ili SFTP (oklopljeni) ili UTP ili FTP (neoklopljen) nema nikakve ralzike sto se tice samog ostvarivanja kontakta sa zicom (osim dodatnog vezivanja oklopa).
Svaki kontakt na RJ-45 konektoru bez obzira da li je oklopljen ili ne, ima par "zuba" koji probiju iozlaciju pojedinacne zice i ostvaruju kontakt.
Samo to ne radi kako treba na punom preseku.
I ne da ume da zeza, nego da ti pamet pomeri dok nadjes sta je.
Da se razumemo... ne pricam o kucnoj mrezi gde par vas zuji po internetu, vec od poslovnoj gde par stotina korisnika "tuce" iz sve snage.
Jedino ako su u pitanju nekakvi specificni konektori, koje jos nisam video (a nagledao sam se bas raznih)
Ajde bas uslikaj neki kad budes u prilici.
Po PS-u se staticna instalacija izvodi kablovima punog preseka, i na njihove krajeve se montiraju moduli, to jest uticnice.
Izmedju uticnice i uredjaja ide patch kabl, koji na krajevima ima konektore i taj kabl je obavezno licnast.
- sarabo
- Poruka: 2278
ako može mala pomoć u vezi aplikacije zoom tj rada kamere u aplikaciji ?
Naime na lap topu imam instaliranu zoom aplikaciju i do juče je ta kamera radila normalno.
Kamera je integrisana i kada je koristim u skype-u ona radi normalno, međutim kad otvorim zoom samo joj sija signalna lampica , ali nema sike.
Operativni je w10, u dozvolama za pristupanje kameri zoom je na listi, u samom zoom-u je čekirana kamera ( kao jedina moguća opcija )..
da li ima još neka caka u podešavanjima ili šta je već problem ?
Fiesta 1.8 d ( 1997 )
- Poruka: 15297
Prvo sto mi pada napamet...
Ubij skype (desni klik na ikonicu u tray-u pa exit), i proveri da nema jos neka aplikacija koja je "prisvojila" kameru.
- sarabo
- Poruka: 2278
Upravo kucam rešenje - prvo sam isključio sve moguće app koje koriste kameru, zatim proverio drivere za kam, isklj/uklj kameru u biosu i ništa
A onda mi padne napamet da proverim update za zoom i gle čuda kamera radi nakon toga.
Kakva glupost, ne znam zašto nije autom povukao update za zoom ako ga već ima
- Poruka: 15297
Auto/rucni update se verovatno podesava negde u samom zoom-u (ne koristim ga, pa ne znam da ti kazem gde).
- sarabo
- Poruka: 2278
Iskopaće njega Bili
Hvala svakako
Hvala svakako
cvrc, natrag za crtaću tablu, opet ne radisarabo piše: ↑subota, 29. maj 2021. u 13:03hUpravo kucam rešenje - prvo sam isključio sve moguće app koje koriste kameru, zatim proverio drivere za kam, isklj/uklj kameru u biosu i ništa
- Poruka: 15297
Ajde uzmi taj lapatope i dodji u Bermet
Sent using Tapatalk
Sent using Tapatalk
- Poruka: 15297
Jbg... kasnis.. vec sam otisao kuci
- sarabo
- Poruka: 2278
Da pročitah na vreme, ne bih okasnio
- sarabo
- Poruka: 2278
do rešenje dođoh skroz idiotskim metodom tj sticajem okolnosti.
naime u jednom od pokušaja provere/ažuriranja drajvera za kameru, jer na netu nađoh podatak da jedan od razloga mog problema može biti taj da ako u datotekama upravljačkih programa za kameru ima onih sa ekstenzijom .SYS velika je verovatnoća da kamera neće raditi na W10... uspeo sam je deinstalirati i obrisati sa kompa.
u device manageru je vratim i pokušam ući u kameru direktno na kompu ( ne kroz zoom ili slično ) i komp je ne vidi..
nakon toga pokušam kroz zoom i ona radi ... kako i zašto nemam pojma.. bitno da radi
Almighty.shO
- Poruka: 1787
21 godinu se bavim racunarima i nikada ovakav problem nisam imao. Hajde da vidimo kako kolektiv razmislja
1. laptop ACER A315-21G-66DW
2. star 2 godine (ili 3)
3. ja licno instalirao Win10 na njega (x64 verziju jer je bio bez OSa)
U pitanju je sestrin laptop i doslo vreme da se srusi Windows. Razlog je sasvim nebitan, inace ovo je rutinska stvar i samim tim sam tom problemu prisao tako...rutinski, ali PRC!
1. USB sa Win10 x64 koji je skinut sa Microsofta, na USB stavljen preko RUFUSa
2. GPT, UEFI
3. BIOS na laptopu je UEFI
4. Podesen boot priority na USB
Restart, boot, cim se pojavi Win10 logo, laptop se restartuje.
Ok, idemo ponovo. Ista situacija.
Dobro, izvadim HDD, proverim ga, sve ok, proverim da li je GPT ili MBR, on GPT. Super.
Sve iznova, ma jok, ni da cuje, samo ga restartuje.
Dobro, idemo dalje.
Izvadim HDD, prebacim ga na MBR, prebacim BIOS na Legacy, prebacim Win10 na MBR (preko RUFUS), sve isto.
Ajmo malo drugacije. Posto Win10 x64 nece, hajde da probamo Win10 x86. Ma jok, ista stvar, nece da instalira. Samo restartuje.
Dobro, uzmem, nabacim Win10 (obe verzije) preko Media Cration tool (sa MS sajta), ma jok, sve isto.
Dakle koja god kombinacija UEFI ili LEGACY, GPT ili MBR, nece da cuje za Win10.
Uzmem Win7, x86, i HOP, instalira ga.
Interesantno.
Uzmem Win7 x64, NECE DA INSTALIRA, odmah restartuje kao i Win10.
Uzmem UBUNTU, i opa instalira ga...
Uzmem Win7, 86 instaliram, i krenem da odradim upgrade na win10, PRC, nece... restartuje...
Dakle, KOJI KU*AC SE DESAVA?
Probao sam preko USB, par komada, preko DVDa, rezao... ma jok... nece da digne Win10 uopste.
I da, laptop je i namenjen samo za Win10 verziju i to x64, ali eto, nekako sljaka sa Win7 x86.
UZAS!
2. GPT, UEFI
Dobro, idemo dalje.
Interesantno.
UZAS!
- Poruka: 15297
Prvo sto bih probao je reset bios-a na default
Drugo, nov, cist disk, na kome nikada nista nije instalirano
Da je sasavo.. jeste..
Moguce je da govance ima neki specifican system driver...
Almighty.shO
- Poruka: 1787
BIOS resetovan x puta.
Probao sa super userom.
Probao da ubacujem fajlove pa da ih BIOS direkt iscita kao boot (zab sam kako se zove opcija)
Moram naci drugi HDD mada je ovaj skroz ispravan, proverio kroz par programa.
Znaci uzeti cekic i razlupati ceo laptop
- Poruka: 15297
Probaj neki od onih wipedisk programa, koji popunjavaju direktno sektore diska sa FF ili 00.
Ne moras cak da ga celog drndas, dovoljan je pocetak diska.
Cisto da budes siguran da nije negde ostalo "nesto" sto ga muci.
Posle toga... ovako "na daljinu"... nemam bas ideja.
Almighty.shO
- Poruka: 1787
Pokusam. Ali moras priznati, bas cudna situacija
- Poruka: 15297
Pogledaj: https://community.acer.com/en/discussio ... ith-win-10
Po simptomima, lici...
I figured it out. Microsoft probably cut some drivers in nowadays ISO and its no longer compatible with this notebook.
I download ISO for 1809 R2 (2018-10) verison via Rufus download tool and it work
Probaj da nadjes neku stariju verziju win 10/64:
