zamena diskova?
pancerFF
Poruka: 1076
Lokacija: Macvanska Mitrovica
Re: zamena diskova?
Poruka od pancerFF » četvrtak, 13. avg. 2015. u 13:06h
Okacio sam link, tako se radi.
Poruka: 6684
Re: zamena diskova?
Poruka od vidovac » četvrtak, 13. avg. 2015. u 14:12h
Ja citah ali nigde ne procitah da vazi za auto sa ABS-om
Poruka: 14988
Re: zamena diskova?
Poruka od mbole » četvrtak, 13. avg. 2015. u 21:39h
Za Mk1 jedina razlika ABS-no ABS koja pise u TIS-u je da se pre postupka otkaci akumulator, i da se posle toga prikaci.
Brake System Bleeding (121410)
Bleeding
Vehicles with anti-lock brakes
1. Disconnect the battery ground cable. For additional information, refer to «Section 414-01».
WARNING:
Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes. Wash hands thoroughly after handling. If brake fluid contacts the eyes, flush the eyes for 15 minutes with cold running water. Get medical attention if irritation persists. If taken internally, drink water and induce vomiting. Get medical attention immediately. Failure to follow these instructions may result in personal injury.
CAUTION:
If brake fluid is spilt on the paintwork, the affected area must be immediately washed down with cold water.
Note:
Make sure that the vehicle is standing on a level surface.
Note:
The system consists of separate circuits for each front and diagonally opposite rear wheel. Each circuit can be bled independently.
All Vehicles
2. CAUTION:
The brake fluid reservoir must remain full with new, clean brake fluid at all times during bleeding.
Install the bleed tube to the bleed nipple.
3. Immerse the end of the bleed tube in a bleed jar containing a small quantity of approved brake fluid.
4. Position the bleed jar base at least 300 mm above the bleed nipple to maintain fluid pressure and prevent air leaking past the threads of the bleed nipple.
5. Loosen the bleed nipple by one-half turn.
6. Operate the brake pedal fully (pumping brake fluid and air into the bleed jar) and allow the brake pedal to return to the rest position.
7. Fill the brake fluid reservoir to the MAX mark.
8. Continue operating the brake pedal until air-free fluid is being pumped into the bleed jar.
9. With the brake pedal fully depressed tighten the bleed nipple.
10. CAUTION:
Make sure the bleed nipple cap is installed after bleeding the brake line(s). This will prevent corrosion to the bleed nipple. Failure to follow this instruction may result in the bleed nipple becoming seized.
Repeat the procedure for the remaining brake lines.
11. Connect the battery ground cable. For additional information, refer to «Section 414-01».
Vehicles with front and rear power windows
12. Initialize the door window motors. For additional information, refer to «Section 501-11».
Djak pesak :)
montoya
Poruka: 2144
Lokacija: Jagodina
Re: zamena diskova?
Poruka od montoya » subota, 15. avg. 2015. u 21:30h
milan_gt piše:ima bre neka posuda sa vakumom itd..ali vidi se da je to totalno nepoznata operacija :D
Ispade da moj dobar ortak, koji mi inace i radi male servise ima ovu alatku, bacvica sa vakumom tako da je ostalo da mi proveri u auto dati koliko kocionog ulja treba da kupim pa da zamenimo...
Ford mondeo mk4.5 2023-
Ford Ka mk2 2021-2025
Volvo v50 1.6 d2 2019-2023
Ford KA 1.3 2019-2021
Maverick 2.0 Zetec 2018-2022
C Max 06. 1.8 tdci 2016-2019
montoya
Poruka: 2144
Lokacija: Jagodina
Re: zamena diskova?
Poruka od montoya » sreda, 19. avg. 2015. u 00:43h
Ljudi jel svako ulje dot4 dobro ili treba da biram? U Jagodini nadjoh bosch dot4 ali u plasticnoj ambalazi da li ima razlike u odnosu na limenku, nadjoh i delphi u euroautu po dobroj ceni od 800 din za litar,pokusao sam da nadjem bosch dot4 super ali ga nema nikako?
Poruka: 11707
Re: zamena diskova?
Poruka od milan_gt » sreda, 19. avg. 2015. u 08:53h
imas ATE racing dot 4 za oko 1.000/L u kit komercu
montoya
Poruka: 2144
Lokacija: Jagodina
Re: zamena diskova?
Poruka od montoya » četvrtak, 20. avg. 2015. u 16:58h
Kupio sam ovo Delphi dot4 super , valjda je ok...
montoya
Poruka: 2144
Lokacija: Jagodina
Re: zamena diskova?
Poruka od montoya » subota, 22. avg. 2015. u 15:23h
Zamenjeno ulje, skine se cep posude zavije drugi koji pravi pritisak u bacvici gde je sipano novo ulje, dok na svakom tocku ispustas staro novo iz bacvice ide u posudu i to je to... Premerio mi je drugar diskove kaze na nekim mestima 1.5 mm su ujedeni, plocice imam jos 6-7mm. Kada se pojedu ove idu i novi diskovi, verovatno na prolece...
Poruka: 6684
Re: zamena diskova?
Poruka od vidovac » subota, 22. avg. 2015. u 20:23h
kakav je utisak kocenja posle menjanja ulja? :)
montoya
Poruka: 2144
Lokacija: Jagodina
Re: zamena diskova?
Poruka od montoya » subota, 22. avg. 2015. u 22:36h
Sve je isto, mislim meni je i ovako kocio odlicno ali ulje je po servisnoj u kocionom sistemu menjano jos 2009. god...
novi81
Poruka: 661
Re: zamena diskova?
Poruka od novi81 » ponedeljak, 31. avg. 2015. u 19:00h
Moj majstor svaki put kad mijenja pločice ozrači sistem. Izvuče dio ulja na svakom točku nekom vrstom vakum pumpe pa dopuni bocu. On to naziva osvježavanje. A na 2-4 godine mjenjam full, tu mi ode oko litar posto ispuštamo više da bukvalno isperemo sistem. Radio sam zamjenu prije nešto više dvije godine kad je rađeno kvačilo. Sipana je Ina Uka 5.1 i u kvačilo i kočnice. Inače čovjek ima dva različita aparata za kontrolu kočionog, jedan mi je zanimljiv jer ima grijač i mjeri precizno tačku ključanja kočionog ulja.
Prije desetak godina sam imao ružnu situaciju da mi propadne kočnica pa sam gledao glavi mjesta. Od tad redovno mjenjam kočiono i ne zajebavam se da tim.
mijat1980
Poruka: 82
Član foruma od: subota, 10. jan. 2015. u 22:11h
Lokacija: Vučić-Rača Kg
Re: zamena diskova?
Poruka od mijat1980 » petak, 25. sep. 2015. u 16:07h
Post su mi faricki diskovi pri kraju a kupio sam nove boshove plocice resio sam i diskove da zamenim. Pa me zanima kakvi su diskovi FERODO premier. Ima li ko iskustva sa njima
bojcistv
Poruka: 2037
Re: zamena diskova?
Poruka od bojcistv » petak, 25. sep. 2015. u 19:33h
Ako je orginal roba to je super marka. Slobodno stavi.
Ford_III
Poruka: 1007
Lokacija: Bor/Pattaya.
Re: zamena diskova?
Poruka od Ford_III » subota, 26. mar. 2016. u 08:56h
Da li na mondea mk3 staje isto 1 litar ulja kocionog i da li moze da se mesa ulje.
Imam pola litra dot 4 pa da kupim jos pola litra ili da kupim ceo litar?I da li da uzmem dot4 ili neki drugi?
Good boys go to Heaven
Bad boys go to Pattaya
85 kw/105 chip.
Poruka: 8314
Re: zamena diskova?
Poruka od FM III » subota, 26. mar. 2016. u 09:57h
Koliko para si potrošio na Tajlandu?
Šta si se stisao za litar ulja ko da je kilo zlata. Ako hoćeš i sledeće godine da ideš tamo kupi bre litar.
ps. u mondeo mk3 ide dot 3 piše na čepu.
Ford_III
Poruka: 1007
Re: zamena diskova?
Poruka od Ford_III » subota, 26. mar. 2016. u 14:08h
Kod mene pise dot 4 super na cepu.
Nisam se stiso nego imam pola litra i to boschovo ulje grehota da se baci.Odavno mi stoji.
Uzeo sam litar ali pomesacu ga sa boschovim.Nego nisam bio siguran koliko staje.Pitao i prodavca pogledao u neki katalog kaze u katalog za forda ne pise koliko staje.Pa sam uzeo litar.Ostatak ce posluziti da se skine farba i necistoca na klestima.
85 kw/105 chip.
shakalkv
Poruka: 878
Re: zamena diskova?
Poruka od shakalkv » subota, 26. mar. 2016. u 15:13h
Ja sam pre 10.000 km stavio nove plocice (original Motorcraft) i diskove (mislim Comline) napred, i vec nekoliko dana mi konstantno cvili jedna plocica na blagom kocenju, uzasno me nervira. Ima li tome nekog leka? I po malo me brine sto diskovi nisu glatki vec imaju useke, mislim da je do sada plocica trebala da nalegne?
Poruka: 8314
Re: zamena diskova?
Poruka od FM III » subota, 26. mar. 2016. u 19:07h
@ Ford_III
Kočiono ulje je higroskopno (upija vlagu iz vazduha) i zato se menja u kolima. Ako ti odavno stoji onda nije za upotrebu u kočionom sistemu.
@ shakalkv
pročitaj ovo: http://www.fordclubserbia.org/forum/vie ... 37&t=13982 ;)
bojcistv
Poruka: 2037
Re: zamena diskova?
Poruka od bojcistv » subota, 26. mar. 2016. u 21:19h
@shakalkv
Nema lijeka za plocice koje cvile nego da se zamijene. A greota da ih mijenjas nakon 10.000 km. Evo kod mene na kolima Samko plocice i Brembo diskovi traju vec 80.000 km. Koliko vidim izgurace i cijelih 100.000 km :). A sve sam platio 140 KM.
Poruka: 21572
Re: zamena diskova?
Poruka od Markedjani » subota, 26. mar. 2016. u 21:22h
treba probati sa podmazivanjem klizača i implementiranje bakarne masti na zadnji deo pločica... može da se desi da će nestati zvuci.
shakalkv
Poruka: 878
Re: zamena diskova?
Poruka od shakalkv » subota, 26. mar. 2016. u 21:27h
I ja mislim da klizaci prave problem. Kad izbacim iz brzine i pocnem vrlo lagano da kocim na semafor, volan se trzne malo u levo i tako stoji dok ga ja ne vratim. Na jacim kocenjima toga nema.
Poruka: 8314
Re: zamena diskova?
Poruka od FM III » subota, 26. mar. 2016. u 21:32h
Ja zbog toga i postavih link, ali neće svi da čitaju.
zeteks
Poruka: 1296
Re: zamena diskova?
Poruka od zeteks » subota, 26. mar. 2016. u 22:10h
shakalkv piše:I ja mislim da klizaci prave problem. Kad izbacim iz brzine i pocnem vrlo lagano da kocim na semafor, volan se trzne malo u levo i tako stoji dok ga ja ne vratim. Na jacim kocenjima toga nema.
Isto i kod mene . Zasto bas se pitam ?
bojcistv
Poruka: 2037
Re: zamena diskova?
Poruka od bojcistv » subota, 26. mar. 2016. u 22:27h
Ako cvile na kocenju onda je do plocica, ako se to desava kada kocnica nije stisnuta onda je do klizaca. Ja sam svoje na desnoj strani mijenjao i sve moji problemi sa klijestima su nestali. Set tih klizaca proizvodi Bosch i u njemu je tuba neke bijele masti koja se stavlja na klizace. Ima evo vec 5 godina ili cak i vise kako sam to napravio i da kucnem u drvo vise nema problema. A za svaki slucaj kupio sam i silikonsku mast za podmazivanje klizaca jer ona ne steze gumice i otporna je na temperaturu.
Ford_III
Poruka: 1007
Re: zamena diskova?
Poruka od Ford_III » subota, 26. mar. 2016. u 22:39h
FM III piše:@ Ford_III
Stoji godinu dana zatvoren u limenoj konzervi.
Ko zna koliko dugo stoje ovi sto se prodaju u magacinima.Tako da mislim da mu isto dodje jbg.
85 kw/105 chip.
