Ma mislio sam da "njerkan" prati forum pa da ga ne cimam na priv. Znam i ja šemu, našao sam na nekom engleskom sajtu al reko da budem siguran. Evo šta englezi pišu:BojanM piše:Kome se obraćaš?
In my case, I discovered that the audio connectors used to connect a CD drive to the motherboard or soundcard in a PC has the correct sized female connections to mate with the pins on the radio. I stuck two of these together back-to-back and cut them down to make a square 4-pin block, then made this into the appropriate cable.
Taman imam neki stari komp koji još nisam bacio pa ću da probam konektore. Evo slika
hvala na odgovoru u svakom slučaju!
