Daljinsko zakljucavanje
dragan...markovic
Poruka: 32
Član foruma od: ponedeljak, 22. avg. 2016. u 20:34h
Lokacija: Nis
Re: Daljinsko zakljucavanje
Poruka od dragan...markovic » sreda, 11. jul 2018. u 16:49h
Pogledao sam danas moj GEM, oznaka je BC, znaci klot :-) moj broj sasije je WF0AXXGCDA2Y23717. Pa ako neko moze da mi pomogne koje oznake za GEM da trazim, a da ima daljinsko.....Focus je rodjen februara 2002, restajling model.....
Ford Focus 1.8 TDCi
Poruka: 15199
Poruka od mbole » sreda, 11. jul 2018. u 21:59h
Spisak je bez podvarijanti, to jest onih koje su naknadno uvodjene kao zamena.
Recimo tvoja BC je zamena za BB.
Kôd: Označi sav tekst
1S7T-15K600-KA From: 15-10-2001  To: 08-01-2002 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-LA From: 15-10-2001  To: 08-01-2002 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  With Perimeter Anti-Theft
1S7T-15K600-BB From: 15-10-2001  To: 07-01-2002 Focus,  Less Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-LB From: 15-10-2001  To: 04-11-2002 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  With Perimeter Anti-Theft
1S7T-15K600-FB From: 01-10-2001  To: 08-07-2002 Focus,  With Central Locking System,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-LC From: 15-10-2001  To: 23-08-2003 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  With Perimeter Anti-Theft
1S7T-15K600-BD From: 15-10-2001  To: 19-05-2003 Focus,  Less Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-KD From: 15-10-2001  To: 30-06-2003 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-LD From: 15-10-2001  To: 23-08-2003 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  With Perimeter Anti-Theft
1S7T-15K600-LE From: 15-10-2001  To: 03-09-2004 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  With Perimeter Anti-Theft
1S7T-15K600-FD From: 01-10-2001  To: 18-08-2004 Focus,  With Central Locking System,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-KE From: 15-10-2001  To: 19-08-2004 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-FC From: 01-10-2001  To: 08-07-2002 Focus,  With Central Locking System,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-KB From: 15-10-2001  To: 08-01-2002 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
1S7T-15K600-KC From: 15-10-2001  To: 08-01-2002 Focus,  With Door Dead Locks,  With Door Entry Remote Control Unit,  Less Anti-Theft Alarm
nemanja93
Poruka: 315
Član foruma od: petak, 9. dec. 2016. u 08:39h
Poruka od nemanja93 » sreda, 11. jul 2018. u 23:34h
Kod mene je bio BB pa sam montirao LA.
U sustini me samo zanimalo daljinsko pa se nisam obazirao sta auto podrzava od ostalih opcija, Djole je to sve namestio u ForsScan-u.
:ford2:
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » četvrtak, 12. jul 2018. u 00:08h
Znaci, fokusiram se samo na one koji podrzavaju daljinsko i samo zamenim, ako sam dobro shvatio? Kljuc narucen preko Alija, po Nemanjinoj preporuci da nije skakavac :-)
Ford Focus 1.8 TDCi
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » subota, 14. jul 2018. u 18:07h
Drugari, nabavip sam GEM i ugradio. Oznaka je GA, centralna sljaka, GEM daje signal nakon 4 okreta kljucem. E sad, jos uvek cekam daljinac pa da ga programiram, ali brine me to sto ne znam sta GA oznaka sve moze jer je nisam nasao ni na jednoj listi...ako neko ima neki info bio bih zahvalan....
Ford Focus 1.8 TDCi
Poruka: 15199
Poruka od mbole » nedelja, 15. jul 2018. u 01:47h
GA je isao u Mondea
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » nedelja, 15. jul 2018. u 07:29h
Da, to sam i ja nasao na netu, ali kod mene radi sve normalno. Zanima me samo da li ce daljinsko da radi kad mi stigne kljuc.
Ford Focus 1.8 TDCi
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » ponedeljak, 16. jul 2018. u 20:23h
Mala pomoc, proslo je par dana od kako sam ubacio ovaj GEM i sve ok funkcionise,ali danas stanem i da ukljucim sva 4, kad ono aaaaargh, ne rade:-), tj rade normalno samo dok drzim dugme pritisnuto, cim pustim prestanu. Da li to ima veze sa novim GEM-om ili mi je, koincidentno, crkao prekidac za sva 4?
Ford Focus 1.8 TDCi
Poruka: 4971
Poruka od Djole » ponedeljak, 16. jul 2018. u 20:34h
Vrati stari pa proveri
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » ponedeljak, 16. jul 2018. u 20:42h
Cim svane :-) vraticu stari pa da vidim
Ford Focus 1.8 TDCi
Poruka: 2078
Poruka od M.M.L. » ponedeljak, 16. jul 2018. u 22:19h
Prekidac daje signal GEM-u da upali/ugasi sva 4 u vidu kratkog impulsa. Mislim da to nije kompatibilno sa tim tvojim od Mondea i da on zahteva konstantan napon da bi palio sva 4.
Poruka: 8355
Poruka od FM III » utorak, 17. jul 2018. u 01:27h
+1 GEM kontroliše sva 4 ;)
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » utorak, 17. jul 2018. u 07:19h
A bas sam se obradovao kako sve glatko ide....
Ford Focus 1.8 TDCi
Lucky
Poruka: 1083
Lokacija: Niš
Poruka od Lucky » utorak, 17. jul 2018. u 09:49h
Cini mi se da u Forscom ima opcije stelovanja kakav impuls treba za sva 4
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » utorak, 17. jul 2018. u 13:42h
5 bambija za one koji su posumnjali na GEM :-).Vratio sam danas stari i sve je ok. Ocigledno da GA ne pasuje kod mene, trazio sam zamenu od Soleta....
Ford Focus 1.8 TDCi
nemanja93
Poruka: 315
Poruka od nemanja93 » utorak, 17. jul 2018. u 13:45h
Forscan, da se podesi.
Moj je takodje podesavan, samo druga stvar bila u pitanju.
:ford2:
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » utorak, 17. jul 2018. u 17:14h
A je l postoji Forscan kao freeware ili.....?
Ford Focus 1.8 TDCi
dragan...markovic
Poruka: 32
Lokacija: Nis
Poruka od dragan...markovic » ponedeljak, 30. jul 2018. u 10:54h
Sve zavrseno. GEM FC, stigao kljuc sa Alija, sve uklopljeno i sljaka. Hvala svakom na dobroj volji i pomoci.
Ford Focus 1.8 TDCi
FF2004B
Poruka: 52
Član foruma od: četvrtak, 12. nov. 2015. u 13:57h
Lokacija: Zemun
ne radi daljinski
Poruka od FF2004B » sreda, 29. avg. 2018. u 19:47h
Desava mi se cudna stvar sa daljinskim, nekad nece da reaguje uopste na pritisak bilo kog dugmeta, a posle par minuta sve normalno. Da napomenem da se ne desava stalno vec ponekad( dosad dvaput).
Jel to baterija pri kraju ili nesto drugo. Auto je fokus mk1 2004 benz.
Poruka: 15199
Poruka od mbole » sreda, 29. avg. 2018. u 19:58h
Najprostije i najjeftinije je zameniti bateriju. Ako nastavi i posle toga, onda je vec nesto drugo, tipa brava, u problemu
Poruka: 6699
Poruka od vidovac » sreda, 29. avg. 2018. u 23:22h
Pomere se tasteri od plastike dole sa kontaktima. Ima jedna plastika koje se vremenom pojede. Najlakse je otvoriti kljuc i ako ona losa skines, i stavis cackalicu drvenu. Ona lepo prodje kroz ruou od elekronike i fiksira se odlicno i nema mrdanja.
Goran33
Poruka: 10
Član foruma od: subota, 23. feb. 2019. u 20:48h
Lokacija: Pančevo
Poruka od Goran33 » sreda, 6. mar. 2019. u 17:12h
Pozdrav, da li neko može da mi kaže koji GEM treba da nabavim da bi imao daljinsko otključavanje i zaključavanje?
Imam Ford focus 1.8 TDCI 115 HP 2004god. karavan. Otvorio sam kasetu i trenutno je u autu model:1S7T-15K600-BE.
Prvo da nabavim odgovarajući GEM a posle ću da narežem novi ključ sa Elektronikom itd...
Pozdav.
Poruka: 4971
Poruka od Djole » sreda, 6. mar. 2019. u 17:40h
Daj kontakt 4x brzo i reci čuje li se beep kao znak potvrde
skolioza
Poruka: 1642
Poruka od skolioza » sreda, 6. mar. 2019. u 18:04h
Da li negde ima da se kupi/naruci kuciste za daljinac od garaznih vrata model Liftmaster 94335e?
Ne treba mi plocica samo kuciste, na mom su se dugmici iskidali, budzio sam nesto ali slaba vajda
Almighty.shO
Poruka: 1781
Poruka od Almighty.shO » sreda, 6. mar. 2019. u 18:18h
Aliexpress? :D
Povratak na „Security“
