Pre neki dan bez razloga pocela je da mi blinka lampica airbaga 4 puta trepne pa ide pauza, pa opet tako u krug... Jel se nekom ovo desavalo i sta moze da bude uzrok?
Unapred zahvalan?
Ford puma 99 Blinka lampica airbaga.. POMOC
- kosta_87
- Poruka: 19
- Član foruma od: sreda, 26. avg. 2009. u 09:43h
- Lokacija: BGD Vozdovac
- Poruka: 15015
Re: Ford puma 99 Blinka lampica airbaga.. POMOC
Imas problem u kolu zatezaca pojaseva (LFC znaci lamp flash code):
Moguce da se samo otkacio neki konektor.
Kôd: Označi sav tekst
ÚÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Item ³ Flash Codes ³
ÃÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ 0 ³ Normal indicator operation ³
³ 1 ³ One flash cycle: Driver air bag circuit LFC ³
³ 2 ³ Two flash cycle: Passenger air bag circuit LFC ³
³ 3 ³ Three flash cycle: LFC common to both driver and ³
³ ³ passenger air bag circuits ³
³ 4 ³ Four flash cycle: LFC common to both driver and ³
³ ³ passenger safety belt buckle pretensioner ³
³ ³ circuits ³
³ 5 ³ Five flash cycle: Driver side air bag LFC ³
³ 6 ³ Six flash cycle: Passenger side air bag LFC ³
³ 7 ³ Continuous light: Air bag control module fault. ³
³ 8 ³ No warning indicator: Instrument cluster circuit ³
³ ³ fault. ³
ÀÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
- kosta_87
- Poruka: 19
Hvala provericu.
