Druga generacija prije facelift-a, 2006. godište, 2.0i 16V, Ghia...
Mirza_Capri_MK1
Poruka: 504
Član foruma od: ponedeljak, 16. dec. 2013. u 22:45h
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » utorak, 6. feb. 2018. u 20:29h
Prije svega hvala svima koji su mi pomogli sa svojim savjetima, iskustvima, preporukama... ... oko kupovine automobila. thumbsuph
Radi se o drugoj generaciji prije facelift-a, 2006. godište, 2.0i 16V, Ghia, hatchback sa pet vrata...
Kupio sam ga u Švicarskoj 30. 01. 2018. godine. Prije mene je imao jednog vlasnika (rođen je 30. 08. 1967. godine mrgreen), prvi put je registrovan 07. 06. 2006. godine (proizveden je 02. 05. 2006. godine u Sea Grey Metallic boji) i automobil je sve vrijeme bio u Luzern-u. Težak je 1327 kg. mrgreen
Kupio sam ga sa 120.XXX pređenih kilometara. Uz njega sam dobio dva ključa i servisnu knjigu.
Oprema je Ghia, a u FordEtis-u piše da je Series 35. A, evo i kompletna lista opreme:
Focus 04-08/Focus C-MAX 03-07, 2.0L Duratec-HE (145PS) - MI4, Sea Grey (Metallic)
Primary Features
Build Date: 02.05.2006
Minor Features
Saarlouis Plant Built
Security Lock Group No.1
Convenience Group No.9
Less Marketing Flex Prep Pack
Less SVO Application/Label
Less Functional Upgrade Pack
Marketing Level 1
With Electronic Stability Control
Less Tyre Repair Service Kit
With Auto Closing Windows
Power Front Windows One Touch Up/Do
Power Rear Window One Shot Up/Down
With Tinted Glass All Round
With Windshield Heat Shielding
With Heated Windscreen
With Cooled Glove Box
With Mini Overhead Console
With Short Floor Console
Front Floor Carpet Mats
With Sun Blinds
With Conventional Headlining
With Illuminated Sunvisor - Drivers
With Illuminated Sunvisor-Passenger
Less Cargo Stowage Rack/Rail
Roof Storage-Driver Sunglasses
Less Roof Rack
With Large Single Wing Rear Spoiler
With Electrochromic R/View Mirror
Drivers Power/Heat/Approach Light
Passenger Power/Heat/Approach Light
With Split Fold-Down Rear Seat
With Rear Center Head Restraint
With Drivers Manual Lumbar Support
With Drivers Heated Seat
With Heated Passenger Seat
With Driver 2 Way Pwr.Seat Adjuster
With Pass 4 Way Manual Seat Adjust
Ignition Flip Key With Remote Unit
With Leather Gear Shift Knob
With Second Remote Ign Flip Key
With Central Locking System
With Door Entry Remote Control Unit
With Automatic Windscreen Wiper
With Headlamp Washer
With Electric Slide Sunroof
Air Curtain Restraint LH
Air Curtain Restraint RH
With Driver Air Bag
With Passenger Air Bag
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
With Steel Spare Wheel
With Standard Rear Shock Absorbers
6.5 x 16" Wheel Style L
205/55VR-16 BSW Tyre
With Standard Suspension
With Mechanical Parking Brake
With Rear Disc Brakes
With Brake Emergency Assist
Less Anti-Lock Braking System
Less Skid Plates
Standard Front Seat
With Fixed Foot Pedals
4 Spoke Leather Steering Wheel
With Speed Control
Less Auxiliary Heater
Conventional Instruments - Level 2
With Instrument Cluster - Rheostat
With Rear Parking Aid
Less Radio Pre-Equipment Pack
(+)RDS
With A/V Jack
With Centre Antenna
High Level With CD And AM/FM Radio
Ice Feature Pack 6
With 8 High Series Radio Speakers
With Column Stalk Radio Controls
With Auto Headlamps
High Intensity Discharge Headlamp
With Front Fog Lamps
With Footwell Lights
Header Mounted Courtesy/Maplights
With Rear Overhead Courtesy Lamp
With Automatic Headlamp Levelling
With Automatic Headlamp Control
Evo i nekoliko slika za početak:
Na dan kada je kupljen.
Dan poslije kada sam izvadio "zoll" table i kupio vinjetu za ovu godinu za Švicarsku.
Na putu kući negdje u Sloveniji.
Ovo je došlo ugrađeno. A, u kutiji su ostavljena njegova originalna fabrička svjetla za maglu. Kada mi je prekidač na nuli onda čim dam kontakt pale se LED dnevna svjetla, a gase se kada upalim pozicije ili kada upalim kratka svjetla. I LED svjetla za maglu se mogu upaliti kada je prekidač na pozicijama ili na kratkim svjetlima.
Slikano jučer.
Jučer je završena homologacija. U toku ove sedmice idem završiti sve do registracije i registrovati ga.
Pa, ćemo pričati o planovima za njega i aluminijskim felgama veličine 17". mrgreen
Danas sam zamijenio termostat i kućište termostata (dok sam se vraćao kući ostao je skroz otvoren) i poziciju u lijevom faru koja je već bila pregorena kada sam ga kupio.
I za kraj dvije zajedničke slike pred sutrašnji rastanak. :)
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Re: Druga generacija prije facelift-a, 2006. godište, 2.0i 16V, Ghia...
Poruka od Mirza_Capri_MK1 » utorak, 6. feb. 2018. u 20:33h
Interesuje me zbog čega piše "Less Anti-Lock Braking System" kada sam pri kočenju sa vrlo male brzine na ledu osjetio tipično korištenje ABS-a? Doduše ne znam je li mi se išta na isntrument tabli pojavilo kada sam kočio, ali sam definitivno siguran da sam osjetio i čuo tipično korištenje ABS-a. Kada dam kontakt i kada se upale sve lampice vidim da ima lampica ABS-a.
Poruka: 4761
Poruka od Nedeljkovic » utorak, 6. feb. 2018. u 20:37h
Bas lepa oprema, daj i neku sliku iznutra, ima li polukozu?
Pametno sto si otisao preko da doteras auto, je l nije tajna koliko si platio zoll table?
Almighty.shO
Poruka: 1787
Poruka od Almighty.shO » utorak, 6. feb. 2018. u 20:40h
Pa kontam da ima ABS.... moj je isto MK2 i to 2005 god pa ima...
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » utorak, 6. feb. 2018. u 20:42h
@ Nedeljkovic Hvala ti! Sjedišta su rekao bih tipična/standardna za Ghia-ju. Plišana. Oba imaju lumbalnu podršku, grijače i podesivi su po visini (vozačevo na struju, a suvozačevo manuelno). Čim ga operem slikati ću ga i iznutra, pa ću staviti slike.
Konkretno za ovaj moj primjerak koštale su me 287 švicarskih franaka (mislim da maksimalno mogu koštati 450 za putničko auto u zavisnosti od marke i modela) i 40 za vinjetu.
Poslednja izmena: Mirza_Capri_MK1, na dan utorak, 6. feb. 2018. u 20:44h. Ukupno izmenjeno 3 puta.
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Almighty.shO piše:
Pa i ja. Zbog toga me i čudi zbog čega piše ono.
Poruka: 5170
Poruka od Sharpshooter » utorak, 6. feb. 2018. u 20:43h
Nemam pojma, ali nema šanse da nema ABS.
Mislim da svaki Ford bar od sredine 90-tih pa na ovamo ima ABS kao standard. Ne računam neke exotike.
Javiće se već neko sa objašnjenjem.
zekavr
Poruka: 440
Lokacija: vranje
Poruka od zekavr » četvrtak, 8. feb. 2018. u 18:41h
Moj predhodni klot focus 99mk1 nije imao abs...
Sent from my HUAWEI VNS-L21 using Tapatalk
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » četvrtak, 8. feb. 2018. u 19:28h
Ima li iko listu/slike OEM aluminijskih felgi koje su dolazile na modele prije facelifta? Imam listu za facelift model, ali nema nekih felgi za koje znam da su dolazile na modelima prije facelifta.
Evo našao sam: https://amaus.net/static/auto/brochure/ ... 202006.pdf
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » petak, 9. feb. 2018. u 20:38h
Danas mi se u toku vožnje upalila Check Engine lampica, svratim do majstora da ga prikopča na dijagnostiku i javlja problem sa EGR ventilom.
Auto ide i najnormalnije se ponaša. Šta mi je činiti?
zeteks
Poruka: 1298
Poruka od zeteks » petak, 9. feb. 2018. u 21:34h
Ako je moguce probajte da ocistite EGR ventil.
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » petak, 9. feb. 2018. u 21:36h
Koje sredstvo da koristim za čišćenje?
kekic91
Poruka: 1019
Lokacija: Žagubica
Poruka od kekic91 » petak, 9. feb. 2018. u 21:59h
Carb cleaner tako nesto
Poruka: 10010
Poruka od macaneli » petak, 9. feb. 2018. u 22:58h
Mirza_Capri_MK1 piše:
Zatvaraj to
Poruka: 5700
Poruka od popovicvl » petak, 9. feb. 2018. u 23:03h
Good EGR is dead EGR.
duratecHE
Poruka: 4277
Lokacija: Gornji Milanovac
Poruka od duratecHE » petak, 9. feb. 2018. u 23:58h
Ma ne verujem da je to do egr... 120k km, benzinac....
Šta da ga zaprlja?
Isteraj ti njega malo ba dzadu, stisni ga i priznaće on šta ga muci, mora se to opali malo :-)
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » subota, 10. feb. 2018. u 00:03h
Pa jerao sam ga. :D Od oko 2000 km pređenih, 70% je otvorene vožnje. Možda ga sutra uz brdo na planinu natjeram.
duratecHE
Poruka: 4277
Poruka od duratecHE » subota, 10. feb. 2018. u 00:11h
Jel ti to sija nonstop ili se ugasi lampica posle par dana
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » subota, 10. feb. 2018. u 00:17h
Tek mi se danas upalila, svratim kod majstora on ga skopča i kaže da javlja grešku na EGR-u.
duratecHE
Poruka: 4277
Poruka od duratecHE » subota, 10. feb. 2018. u 00:24h
Sacekaj dan dva možda ugasi. Meni je upalio- sam ugasio u 2 navrata kada mi bila svećica u proboju.
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » subota, 17. feb. 2018. u 14:39h
U srijedu EGR skinut i ociscen. Bio je malo prljav.
Sve je bilo uredu nekoliko dana do danas, kada se lampica opet upalila.
Majstor mi kaze da elektronika EGR-a ne otvori (ili sta vec treba da uradi) na vrijeme i on prijavi gresku.
Kaze da ima EGR od MK3 Mondea sa istim 2.0 Duratec motorom, pa da probamo taj staviti.
duratecHE
Poruka: 4277
Poruka od duratecHE » subota, 17. feb. 2018. u 15:14h
Probaj...
Otvara na 1800/ min
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » četvrtak, 22. feb. 2018. u 18:36h
Kako i gdje mogu vidjeti na koliko se kilometara/godina šta mijenja na autu?
kekic91
Poruka: 1019
Lokacija: Žagubica
Poruka od kekic91 » četvrtak, 22. feb. 2018. u 18:43h
Pitaj sta te interesuje i recicemo ti,mislim da ces tesko da nadjes na netu nesto oficijalnog tipa a da nije forum itd a ako ti je lakse imas knjigu i tu mozes da vidis,inace ja mislim da ti je nalakse da pitas ovde
Mirza_Capri_MK1
Poruka: 504
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » četvrtak, 22. feb. 2018. u 18:50h
Imam servisnu knjigu. Mislio sam da to mogu naći u ETIS-u, ali nisam se baš snašao.
Čuje mi se mikro remen klime kada je hladno. Kada se auto duže vozi i kada se sve ugrije, više se ne čuje. Također ako ga poprskam WD-om, više se ne čuje. Kontam da je izgubio elastičnost od starosti i da je vrijeme da ga mijenjam.
Originalan u ovlaštenom košta 60-65 Eura sa onim alatom, sa kojim se stavlja.
I šta su "Auxiliary drive belts"? Remenje?
