Escort V, CVH, FIlteri i jos po nesto...
oristic
Poruka: 1035
Lokacija: Nis
Poruka od oristic » sreda, 13. jan. 2010. u 12:27h
Na koliko se km menja filter vazduha na Escortu V, CVH motor, voznja iskljucivo na plin! Preso sam vec 20k od poslednej zamene!!!
Da li postoji filter goriva i ge se on nalazi, posto ni pumpu ne vidim? , a kazu nije potapajuca?
Da li je potrebno i koliko cesto zameniti skroz ulje za servo i koje se sipa i koliko l staje?
A antifriz?
Mozda mnogo pitam ali nailazim na oprecne stavove nekih nazovi majstora!! Hvala!
shomicus
Poruka: 675
Lokacija: Bgd,Vozdovac
Re: Escort V, CVH, FIlteri i jos po nesto...
Poruka od shomicus » sreda, 13. jan. 2010. u 13:03h
evo sta kaze servisna knjiga,doduse za nov auto i original delove,za ove zamenske racunaj pola od te kilometraze:
Every 20 000 miles
Carry out all operations listed above, plus the following:
Renew the spark plugs - HCS and CVH engines only
Extended service - every 30 000 miles
or 3 years, whichever occurs first
Renew the coolant (Section 28)
Renew the air cleaner filter element (Section 29). Note
that this task must be carried out at more frequent
intervals if the vehicle is used in dusty or polluted
conditions
Check the Positive Crankcase Ventilation (PCV) system,
and clean the filter (Section 30)
Renew the spark plugs - Zetec engines only (Section 27)
Check the oil filler cap - HCS engines only (Section 31)
Renew the automatic transmission fluid (Section 32)
Check the handbrake adjustment (Section 33)
Every 60 000 miles
Renew the timing belt (Section 34)
Renew the fuel filter (Section 35)
oristic
Poruka: 1035
Lokacija: Nis
Poruka od oristic » sreda, 13. jan. 2010. u 13:26h
To je sve OK, hvala, ali bih vise voleo neku iskustvenu varijantu, auto se vozi na plin tako da se tu stvari menjaju dosta (svi kazu da filter vazduha mora cesce da se menja), a i na trzistu znamo svi kakvi su delovi u pitanju, a i tecnosti (ulja, antifriz...)!!!
MaxBunker
Poruka: 238
Član foruma od: utorak, 17. mar. 2009. u 23:36h
Poruka od MaxBunker » sreda, 13. jan. 2010. u 16:09h
Dovoljno je filter vazduha mijenjati na 10 000 km. Gas štedi ulje, pri zamjeni ono bude čistije nego kod benzinaca.
oristic
Poruka: 1035
Lokacija: Nis
Poruka od oristic » sreda, 13. jan. 2010. u 18:51h
Znaci preterao sam sa 20k? Pitam zato sto se neki prave pametni i kazu da treab da se vidi koliko je zaprljan, ja mislim da je to manje bitno vec filtere treba menjati po broju km, pa ce nekad biti manje nekad vise zaprljan, zavisi od mnogo cega!!!
A moze li mi neko reci nesto o ostalim stvarima, po iskustvu?
MaxBunker
Poruka: 238
Poruka od MaxBunker » sreda, 13. jan. 2010. u 19:22h
Ma nisi pretjerao sa 20k ako nije bilo problema. Filter može otići i za 5 000 km ako motor baca ulje na iberlauf, i ako si često na prašnjavim putevima. S druge strane, moj prijatelj nije nikad mijenjao filter, a kupio je auto (Golf I) prije četiri godine, i dosta ga vozi.
Pošto je kod tebe motor sa karburatorom, onda imaš običnu AC pumpu, mehaničku, a ona je naprijed kod motora. Filter bi trebao biti između AC pumpe i karburatora. Moguće je i da ga nema uopšte. Vidio sam slučajeve, filter se zapuši, a majstor umjesto da ga zamijeni, samo stavi komad crijeva.
Što se tiče antifriza, postoje verzije sa rokom trajanja od 2, 3 i 5 god(G12). Ovaj zadnji je skuplji i ide u novije motore. Ne moraš se baš strogo držati intervala zamjene kao kod ulja, ali ne treba ni pretjerivati kao moj komšija (gdje ja to živim lol ) koji ima Yuga 45 1991. godište sa fabričkim antifrizom !
shomicus
Poruka: 675
Poruka od shomicus » sreda, 13. jan. 2010. u 19:59h
ja pre neki dan kupih g12 za 260 din na mb gas pumpi.Valjda mu nista ne fali,pre 20ak dana sam kupio u rodicu odrali me 480 din po litri,cini mi se valvoline g12.
oristic
Poruka: 1035
Lokacija: Nis
Poruka od oristic » sreda, 13. jan. 2010. u 21:44h
Puno hvala na savetima! Iskreno auto je kod mene 2 god. ali nisam menjao antifriz samo dodavao 100% da ne bi ledio pred zimu, moram to da zamenim. Kolika je litraza, za 1.6 CVH, ukupna?
Jos me zanima sta je sa uljem za servo, ima jedan post ali se tamo nisam pronaso, koliko se cesto menja (neki kazu da i ne menjam nego da dosipam ako zafali), koliko staje i koliko l? Nivo mi ne opada!
Jedan laik mi rece da mi je pumpa za gorivo na bregastoj, jel to moguce?
Poruka: 5135
Poruka od Neša » petak, 15. jan. 2010. u 21:20h
Na 1.6 CVH meni je stalo 3l destilovane i 3l G12 i kasnije sam dolio vrlo malo destilovane. Imas Basf G12 antifriz za 280din,destilovana je 30din.
Ja sam stavio Total antifriz,malo vise od 300din kosta. Pozdrav
Poruka od van » petak, 15. jan. 2010. u 22:07h
Pumpa za gorivo je kod bregaste osovine kada je auo sa karburatorom . Ako je efi ili cfi , onda ima elekto pumpu
oristic
Poruka: 1035
Lokacija: Nis
Poruka od oristic » subota, 16. jan. 2010. u 00:07h
Hvala svima, a servo ulje? Na koliko menjati (neki mi rekli da i ne menjam), sta sipati, koliko staje?
Poruka od 911s [SK] » nedelja, 17. jan. 2010. u 20:36h
Ne bi trebalo da menjaš, samo dolivaj.
Poruka: 21847
Poruka od Markedjani » nedelja, 17. jan. 2010. u 20:46h
Napisao u drugoj temi... očigledno pišem za džaba.
ATF dexron II ulje... menja se na svakih 5 godina... ne znam koliko staje.
oristic
Poruka: 1035
Lokacija: Nis
Poruka od oristic » nedelja, 17. jan. 2010. u 22:28h
Ok, hvala, nije za dzaba!
Video sam i tamo, potegnuta je prica o uljima pa sam se nadovezao za pitanje - tamo na onom postu, a ovde je dugo pitanje bilo bez odgovora!!!
