Imobilaizer active
- Poruka: 3
- Član foruma od: nedelja, 31. maj 2020. u 15:38h
Imobilaizer active
Pozdrav
Nakon promjene akumulatora na ford mondeo g. 2010 titanium javlja mi gresku imobilaizer active. Ima li ko ideju kako to rijesiti.
Marko
Marko
- Poruka: 1781
Re: Imobilaizer active
Koji akumulator i koji je napon na njemu?
- Poruka: 15067
Malo vise detalja...
Keyless ili kljuc, koji motor...
Da li si pokusavao da ga upalis na kablove pre zamene akumulatora ili nisi...
Ako se dobro secam, na njemu treba odraditi reinicijalizaciju stanja baterije.
Pokusaj:
1. Get in to the car and do all from points 2 to 4 within 10 seconds.
2. Turn on ignition with engine off (key in position II) .
3. Turn on and of 5 times rear fog light switch .
4. Turn on and of 3 times hazard light switch .
5. If everything goes OK battery light will flash 3 times on cluster within next 15 seconds.
6. Reseting BMS counter finish.
Little tips before questions start, to make fog lights working you need to do this with headlights "on".
This procedure is also applicable to Ford Smax which got battery counter.
These models which don't have battery counter this procedure simply do nothing.
Pokusaj:
- Poruka: 3
Hvala vam na odgovoru. Izgleda da je greska u kompjuter motora.
- Poruka: 1781
Ne, nego si zeznuo prilikom menjanja akumulatora.
Sve se to da resiti. Isprati ovo sto je mbole napisao.
