Ford Focus mk3 - Provera VIN koda ?
Maxim76ns
Poruka: 4
Član foruma od: utorak, 19. sep. 2017. u 23:03h
Poruka od Maxim76ns » četvrtak, 4. jun 2020. u 10:24h
Dobar dan svim fordovcima,potrebna mi je pomoc naime vozim focus mk3 2012 1.6tdci 70kw, imao sam udes nedavno ostecen mi ceo prednji kraj menjana hauba farovi branik nije ispalio air bag ni jedan sredjeno je u servisu sve samo se meni cini da majstori nisu stavili onu klapnu za vazduh ili kako je zovu active grill,ja mislim da sam je imao na autu, ako bi neko mogao da proveri preko broja sasije dal je fabricki ugradjena bio bih vam zahvalan i da proveri koja je oprema focusa.WF0KXXGCBKCS03605.Svaka pomoc je dobrodosla jel se natezem sa osiguranjem,izvinjavam se na duzem postu.
sarabo
Poruka: 2262
Re: Potrebna pomoc
Poruka od sarabo » četvrtak, 4. jun 2020. u 10:27h
ovo ti je spisak šta ima tj nema od opreme
Wheel Size & Style 16 Inch 6.5J X 16 Steel Wheel
Engine Cover - Under Hood Engine Cover - Under Hood
Front Fog Lamp Type With Front Fog Lamps
Suspension Types With Standard Suspension
Front Seat Type Standard Front Seat
Marketing Flex Prep Pack Marketing Flex Prep Pack 9
Door Mirror Finish With Body Coloured Exterior Mirror
Tinted Glass With Tinted Glass All Round
Door Locking Systems With Central Locking System
Headlamp Levelling Type With Manual Headlamp Levelling
Speedometer Types With KMH Speedometer
Drivers Seat Adjustment Type With Driver 4 Way Mnl.Seat Adjuster
Marketing Levels Marketing Level 1
Passenger Seat Adjustment Type With Pass 2 Way Manual Seat Adjust
Door Remote Control Unit With Door Entry Remote Control Unit
Front Headrests With Front 2 Way Headrest
Fuel Tank Lock Non Locking Capless Fuel Fill
Rear View Mirror Type With Dipping Rear View Mirror
Fresh Air Heater With Recirculating Heater
Starter Motor Type Starter - Stop/Start System
Wheel Lug Nuts Non Locking Lug Nuts
Rear Headrest Type With Integrated Rear Headrest
High Mounted Stop Lamp With High Mounted Stop Lamp
Shutters - Radiator With Kysor Radiator Shutter
Rear Passenger Door Rear Passenger Door
Batteries Standard Duty Battery
Headlamps - Design With Halogen Headlamp
Rear Bumper Rear Bumper Body Coloured Plastic
Tripminder With Trip Computer
Side Air Bag - Passenger Side With Side Air Bag - Passenger Side
Brake Calipers And Pads Standard Duty Fr/Rr Calp And Pads
Door Handle - Exterior Body Coloured Exterior Door Handle
Load Floor Covering With Load Floor Carpet
Fog Lamp Bezel With Bright Fog Lamp Bezel
Rear Shock Absorber Type With Standard Rear Shock Absorbers
Headrestraint - Rear Center With Rear Center Head Restraint
Air Curtain Restraint(RH/LH) Air Curtain Restrnt LH
Tailgate Release With Remote Controlled Tailgate Release
Rear Seat Belts Retractable Rear Seat Belt-3Point
Front Seat Belt Mounting With Manual Adjust Frt.S.Belt Mount
Steering Column Types With Manual Tilt/Slide Stg Column
Load Compartment Lamp With Load Compartment Lamp
Air Curtains (Use CP1 Family) Air Curtain Restrnt RH
Headlamp Bezels With Aluminium Headlamp Bezels
Front Tyre Tread Pattern With Standard Tyre Tread - Front
Rear Tyre Tread Pattern With Standard Tyre Tread - Rear
Foot Pedal Design Standard Foot Pedal Pad Design
Power Point Rear With Power Point Plug - Rear
Isofix Hard Point Attachment With Isofix Hard Point Attachment
Side Air Bag - Drivers Side With Side Air Bag - Drivers Side
Passengers Air Bag With Passenger Air Bag
Instrumentation Type Conventional Instruments - Level 3
Rear Window Operation With Manual Rear Windows
Drivers Air Bag With Driver Air Bag
Adjustable Foot Pedals With Fixed Foot Pedals
Seatbelt Anchorage 3 Part Seat Belt- European Regultn
Smokers Package With Smokers Package
Centre Console Console - With Closed Bin
Tailgate Badges Econetic Tailgate Badge
Windscreen Wash/Wipe With Variable Intermittent Windscreen Wiper
LH Arm Rest With LH Front Door Armrest
Single Note Electric Horn Dual Note Electric Horn
Parking Brake Grip With Plastic Moulded H/Brake Grip
Steering Wheel Radio Controls With Steering Wheel Radio Controls
Exterior Tailgate Handle Body Coloured Tailgate Handle
Corporate Badge Ford Corporate Badge
Drv St Back Mtd Map Pocket With Driver Seat Back Map Pocket
Outer Rocker Panel Moulding Colour Rocker Panel Moulding -Cladding C/K
Exterior Paint Pack Exterior Paint - Solid
Lumbar Seat Support Driver Seat With Drivers Manual Lumbar Support
Rear Brake Type With Rear Disc Brakes
In Car Entertainment ICE- Mid Audio (1C) W/Connectivity
Pass Seat Back Mtd Map Pocket Passenger Seat Back Map Pocket
Steering Types With Electric Power Steering
Plant Build Requirements Saarlouis Plant Built
Reverse Parking Aid With Rear Parking Aid
RH Arm Rest With RH Front Door Armrest
Engine Immobilizers With Engine Immobilizr - Securilock
Grille - Upper Grille - Upper Chrome Bar/Surround
Kit-Tyre Repair Service Kit - Enhanced Tyre Repair SVC
Grille - Lower Grille-Lower Surround - Dk Slf Clr
Navigation Data Navigation Data - Western Europe
Child Proof Locks With Child Proof Safety Lock
Radio Speakers With 6 Speakers
Parking Brake - Function Type Mechanical Hand Operated Park Brake
Front Towing Hooks With Front Towing Hook
Fuel Filler Door Lock Capless Fuel Filler Without Lock
Wheel Covers Wheel Cover - Style A2
Cold Start Type Cold Start -29 Deg C
Temperature Zones For Normal Temperature Zones
Seat Belt Warning Type With Drvr/Passngr Seat Belt Minder
Second Remote Ignition Key With Second Remote Ign Flip Key
Rear Towing Hooks With Rear Towing Hooks
Glove Box Lamp With Glove Box Illumination
Steering Wheel Type Basic Type Steering Wheel
Module Configuration Outside Air Temperature Present
Tether Anchorage Style 1 Tether Anchorage Restraint
Drivers Recliner Seat With Driver Seat Recliner - Rotary
Instrument Cluster - Rheostat With Instrument Cluster - Rheostat
Fuel Capability Type With Diesel Fuel Capability
Front Window Operation Power Frt Window-1 Tch Dwn-Dr Only
Exterior Mirror Dual Dual Power Htd Signal Mirrors
Rear Window Wash/Wipe With Int. Rear Window Wiper/Washer
Interior Feature Colour Int Feat Colour - Charcoal Black
Interior Door Handle Type With Aluminum Interior Door Handles
Gearshift Knob With Moulded Gearshift Knob
Tail Lamps Tail lamps - Level 1
Padded Dash With Padded Dash
Ignition Key Type Ignition Flip Key With Remote Unit
Temp Controlled Drivers Seat With Drivers Heated Seat
Transmission Gear Sets 3.72/2.04/1.25/.919/.738/0.622
Load Compartment Cover With Load Area Cover
Interior Environment Colour Int Environment Clr-Charcoal Black
Rear Fog Lamps With Single Rear Fog Lamp
Temp Controlled Passenger Seat With Heated Passenger Seat
Maplight With Front And Rear Lamp Bulb
Rear Spoiler Type With Rear Spoiler
Accessory USB Unit Accessory Media Hub 1XUSB
Integrated Control Panel ICP Nav
Rear Side Air Bag
Media Gateway Module With Media Gateway Module
Auxiliary Heater With Supplemental Air Heater
Overhead Console With Mini Overhead Console
Air Purifier Pollen/Carbon Filter
Folding Rear Seat Type With 60:40 Split - Folding Rr Seat
Message Centre With Message Centre
Passenger Recliner Seat With Passenger Seat Recliner-Rotary
Liftgate With Manual Liftgate
Rear Seat Cushion Type With Two Piece Rear Seat Cushion
ICE Feature Pack With ICE Feature Pack 11
Sunvisors - Passenger Sunvisor-Pass Vinyl W/Mirr Insert
16 Inch Tyres 205/55VR-16 BSW Tyre
Anti-Lock Brakes With IVD/Traction Control/ABS
Headlinings With Conventional Headlining
Emergency Call Systems Emergency Assistance
Front Bumper Front Bumper - Painted Body Colour
Multi Function Display MFD Nav Low TFT Screen
Exhaust Systems Single Exhaust
Sunvisors - Driver Sunvisor-Driver Vinyl W/Mirr Insert
Fiesta 1.8 d ( 1997 )
Maxim76ns
Poruka: 4
Re: Potrebna pomoc
Poruka od Maxim76ns » četvrtak, 4. jun 2020. u 10:36h
Hvala na brzom odgovoru za opremu posto mi je ovaj iz osiguranja napisao da je paket opreme trend, pa me to malo bunilo posto ima navi fabricku i displej ispred vozaca veci nego u trend opremi sto se prodavala kod nas.
motoRISTA
Poruka: 256
Član foruma od: subota, 25. maj 2019. u 00:45h
Re: Potrebna pomoc
Poruka od motoRISTA » petak, 26. jun 2020. u 16:26h
sarabo, kako mogu da vidim ovakav spisak za svoj auto?
Poruka: 15273
Re: Potrebna pomoc
Poruka od mbole » petak, 26. jun 2020. u 17:52h
sarabo
Poruka: 2262
Re: Potrebna pomoc
Poruka od sarabo » petak, 26. jun 2020. u 21:46h
ili daj broj šasije ...
motoRISTA
Poruka: 256
Re: Potrebna pomoc
Poruka od motoRISTA » petak, 26. jun 2020. u 23:44h
Hvala obojici, uspeo sam sam. Odlična stvar.
