C-max 2007 temperatura iz F u C
YOmax
Poruka: 647
Lokacija: beograd
Poruka od YOmax » četvrtak, 13. okt. 2022. u 15:38h
Kako da prebacim temperaturu u celzijuse?
Promenio sam jezik na English(UK) i stavio na metric. I tada je prešlo na KM sa MLS. Ali je temperatura ostala na 71'F
Unapred zahvalan
Sent from my SM-S908B using Tapatalk
Poruka: 15071
Re: C-max 2007 temperatura iz F u C
Poruka od mbole » četvrtak, 13. okt. 2022. u 16:10h
https://www.fordservicecontent.com/Ford ... bled=False
Units of measure
To select metric or imperial units:
Toggling the units of measure using this display will affect the following displays:
Distance to empty.
Average fuel consumption.
Instantaneous fuel consumption.
Average speed.
Outside air temperature.
The temperature display in the automatic climate control.
Note: The units of measure for outside air temperature and the automatic climate control can be toggled independent of the other displays. When showing the outside air temperature, press and hold the SET/RESET button for a short time.
Use the rotary control to enter the main menu.
Highlight Setup and press the SET/RESET button.
Highlight Display and press the SET/RESET button.
Highlight Measure Unit and press the SET/RESET button.
Highlight the desired setting and press the SET/RESET button to confirm the setting.
Highlight Back and repeatedly press the SET/RESET button to return to the main menu.
YOmax
Poruka: 647
Lokacija: beograd
Poruka od YOmax » četvrtak, 13. okt. 2022. u 16:38h
Provalio sam.
Dok stojiš udješ u Meni i kad se dodje do Temperature pridrži se duže Set dugme i prebaci se na onu meru koja nije bila(iz C u F i obrnuto)
Hvalaa :)
