Pozdrav svima,
U nastavku aktivacioni kod za Forscan
Your activation code is:
FSEL-BDR9-KRDR-W14F
Valid until 16-04-2024
Please activate your license(s) as the following:
1) Make sure you have latest version of FORScan for Windows installed (2.3.52 or more new).
2) Run FORScan and go to the About section (last item in the main menu).
3) Press "Enter Activation Code" button.
4) In the dialog opened please enter the activation code you received in email. Note: we strongly recommend copy & past the code (not type manually) to avoid mistakes.
5) Wait for activation result and confirm restart of FORScan. Note: if activation fails, please check your PC firewall settings and make sure FORScan outcoming connections are not blocked.
6) After restart the Extended License is installed and application is ready for use.
The activation code is valid during the whole license validity period. In case of laptop replacement, Windows reinstallation etc you may need to use the code to activate FORScan Extended license again. Please keep the activation code safe.
In case of problems with activation, please contact FORScan Support Team at [email protected] .
If you want to join the FORScan forum, please use this invitation code for registration:
FORScan activation code for Windows
- Poruka: 6
- Član foruma od: nedelja, 25. dec. 2022. u 17:28h
- Poruka: 2065
Re: FORScan activation code for Windows
Zasto delis aktivacioni kod? Dajes ga besplatno ili imas neki problem?
- #47
- Poruka: 76
- Član foruma od: ponedeljak, 19. jul 2021. u 21:55h
Aktivacioni kod je vezan za uredjaj, tako da na nijednom drugom uredjaju osim njegovom nece moci da radi..
- Poruka: 448
- Član foruma od: petak, 9. mar. 2018. u 08:15h
Licenca za godinu dana 10e
